Previous in Forum: Mechanical Interlock For Two Incomers   Next in Forum: Engineering Projects
8 comments
How to design wind turbine blade
07/31/2010 10:33 AM
hi friend, i am a fresh man on desining a wind turbine blade. May u all pls teach me on what should take concern and what is the most important parameter that will influence the efficiency on a wind turbine?
Re: How to design wind turbine blade
07/31/2010 11:41 AM
I think the Engineering department is working on wind turbine projects. I found this website and think it is the one.
What I know for certain is I saw them making blades out of 2X8's a few weeks ago.
Drew
07/31/2010 12:46 PM
[PDF] Blade layout and carving
Drew K, that is a cool web site.
07/31/2010 1:32 PM
I haven't had much time to look into it. I am just finishing my first summer here at WTAMU. If I get to stay for the fall I will probably be working on it too, or at least know more about it. I should find out next week if I get the R.A. job that will let me attend classes here, if not I will take another semester elsewhere.
Drew
Good Answers: 204
07/31/2010 10:44 PM
the most important parameter is RADIUS.
Radius begets torque. Torque begets power to turn generators.
As to efficiency, the starting speed of the turbine is important, so you can capture as much of the motion of the air as possible in its range of possible speeds.
It would pay to search cr4 and read what has been posted before.. there is a wealth of info and links already here.
Chris
Hobbies - Target Shooting - New Member Hobbies - Fishing - New Member
Good Answers: 12
08/01/2010 8:06 PM
You Tube has several videos on making turbine blades. Check them out.
08/05/2010 1:38 AM
06/26/2012 8:09 AM
hi guys, thanks for your information. it really help me alot.
thanks.
Good Answers: 12
06/26/2012 3:17 PM
I have been impressed with laminating stamped sheets of material together. I am wondering if someone has designed blades in multiple layers that could be cut out with a saw, and then glued together. They would be of different sizes that lead to the desired form. I believe that airplane rotors were originally made this way. I know there is a problem with getting the balance right, but would think that shaping and sanding could solve that. I don't remember the technique for balancing though.
Casting aluminum might be a lot easier. I have not heard of aluminum turbine blades, maybe there is a reason.
Register to Reply 8 comments
chrisg288 (1); dadw5boys (1); Drew K (2); lyn (1); ronwagn (2); syeltang87 (1)
