Previous in Forum: Free Pipe Stress Analysis Software   Next in Forum: Excess Air in Gas Fired Boiler
VARS
08/01/2010 10:03 AM
What would be d space reqd. & weight of a vapour absorption refri. systm(use of exhaust heat) installed in a vehicle(ATV)[refrigeration space volume around 20 cu.ft.] having a capacity of less than 0.5 TR?
Also,suggest d best possible absorbent pair(1 being a refrigerant)
Pathfinder Tags: activated charcoal LiBr VARS
Re: VARS
08/01/2010 6:43 PM
I think this is a bit larger than the average RV absorption refrigerator. Wild guess 200 pounds and 5 ft3 for the "high side." This assumes that the evaporator ("low side") is contained within the 20 ft3 box. This will depend on the configuration of the exhaust gas heat exchanger. The normal refrigerant choice is ammonia with water as the absorbent, plus a buffer charge of hydrogen on the "low side" to nearly equalize total pressure throughout the system.
Household refrigerators used to be mfd by Electrolux and Servel, and maybe still are. One RV mfr is Dometic. There are others as well.
Good Answers: 19
Re: VARS
08/01/2010 11:05 PM
We have a small Dometic absorbtion refrigerator in our small 10 year old RV camper. It can be switched between propane, 12VDC and 120VAC for heat source. From the owner's manual we have it sounds like the refrigerant pairing is ammonia and hydrogen.
Unit is approximately 21.5 inches high, 19.5 inches wide, and 21.5 inches deep. The manual does not provide refrigeration capacity, but based on experience this year (we purchased the camper used) the performance is less than 0.5 TR. Check these sites
http://www.dometic.com/enie/
http://www.dometic.com/enus/Americas/USA/RV-Products/refrigerators/
If you are looking for a model for outside the USA, use the first link to find the correct ccountry.
Re: VARS
08/01/2010 11:45 PM
This sounds about right, along with the tonnage estimate.
Register to Reply 3 comments
