Previous in Forum: Electric Torque Wrench   Next in Forum: Self Locking Gear
Patch Plate Thickness
08/03/2010 12:49 AM
Anybody help to find out the calculation for patch plate for the following case:
We want to servive safely up to 2012 end with additional patch plate.
Column Material – SA 516 Gr-70
Design pressure – 9.5 Barg
Design Temp- 206 Degree C.
Nominal thickness- 18.02 mm
Present actual thickness – 14.45 mm
Design minimum thickness required- 13.83 mm
In year time Corrosion rate-3.57mm/year
CA-3 mm
Re: Patch Plate Thickness
08/03/2010 5:14 AM
Can you be more clear?
Please Define: Purpose, Requirement, Location, Internal/External, Vessel Configuration (including Internals).
is it local corrosion that prompted you to decide upon a patch plate?
Reply to Forum Thread
