Previous in Forum: Patch Plate Thickness   Next in Forum: Displacement Stress Range
Self Locking Gear
08/03/2010 1:04 AM
Good day Sir,
In the 150 tonne hydraulic crawler crane, to lifting the boom and load, they use pump to drive motor. As motor rotated, it make the worm gear rotate together. and the spur gear rotate too. So the winch rotate and the boom is lifted. I know that the worm gear can be Self Locking as the lead angle of the worm is less than the friction angle. But when I remove the motor out of system,heavy boom make the spur gear rotate, and incrediblly the worm gear rotate too. I mean the worm gear CAN NOT Self Locking. So please help me to solve this probem, I think,after long time in service. The worm gear loss ability of self locking due to wear.SO the coefficient friction between the worm and the gear be changed. Is it possible ? Thanks a lot
Re: Self Locking Gear
08/03/2010 3:20 AM
Contact the crane's manufacturer.
Good Answers: 58
08/03/2010 5:01 AM
Use of worm and wheel in a lifting machine application is not uncommon but it is not, to the best of my knowledge, accepted as a fail safe mechanism for the prevention of uncontrolled lowering of loads.
Quote below is from this site.
SAFETY PROVISION: Worm gearing should not be used as a locking mechanism to hold heavy weights where reversing action can cause harm or injury. In applications where potential harm is non-existent and self-locking is desired against backward rotation then use of a single thread worm with a low helix angle automatically locks the worm gear drive against backward rotation.
Register to Reply 2 comments
