Previous in Forum: How to Decide the Suitable L-Angle   Next in Forum: O Ring Surface Requirements
8 comments
Hydraulic Calculations?
08/03/2010 1:10 PM
Hi!
I'm not too familiar with the hydraulics field. I mean i understand how it works, but I have never done some calculations until now, and since the lack of literature i need some help with it (and/or recommendations on some really good literature i could learn how to do it from).
I'm working on some paper about running a centrifugal pump using a hydraulic motor.
The hydraulic motor is adjustable, while the pump that runs the system runs with constant rpm.
It's really a simple system with little count of elements.
The first problem i encountered is the filter. Both the pump and the motor require filtration of the oil with max particles size 5 micrometers)
The pump is normally located next to the oil tank. Since suction filters aren't recommended and if they are used filtration below 100 micrometers isn't recommended, having trouble deciding where to put the filter? If i put it in the pressure line it's possible the pump sucks something bigger than 5 micrometers isn't it?
The second question is the tank? I've been searching how to determine the needed size of the tank, and found some formula that says that the volume is 1,5 * Vc, where the Vc is the volume of all cylinders in the system. Since I don't have any cylinders in the system i thought the Vc would indicate the displacement volume of the hydromotor should be put in instead, but that's not right since i get the needed volume needs to be less than 1 liter.
That's the trouble i have in the moment, there will surely be more, hope I can find answers here when i stumble on some problem, although I'd like to get a great book recommended where i can learn how to do the calculations (summed up what i need to calculate is: the filter, the oil tank volume, the cooler, losses and how much it'll get heated, so thanks in advance for the recommended books and all the help you'll be able to give me)
Re: Hydraulic calculations?
08/03/2010 3:56 PM
Is this work, or homework?
What drives the hydraulic motor that drives the pump?
What makes you think the pump will be exposed to hydraulic fliud? Wouldn't it be driven by a shaft from the motor to the pump?
With no cylinders, the volume of working fluid will remain constant, except for thermal heating.
Fess up. What are you really trying to do?
08/03/2010 4:22 PM
Well it's kind of both. I decided to go make a let's say essay about a topic i don't know much about but will help me in the future on my job i do...... I know how to do schematics, but never done any calculations and that's what i'm trying to learn at moment. The problem is the books i have don't give me much info about it, so that's why i asked about some recomendations for books.
The system is very simple. The engine of a vehicle or separate fuel engine drives a hydraulic pump with constant speed. The pump spreads the hydraulic oil further in the system towards the hydraulic motor that drives the centrifugal fire pump. Between the pump and the motor there is a valve that's used for regulating the speed of the motor (the centrifugal fire pump requires change of speed due to more than one consumer which effect the flow of the firefighting system).
So i ran onto some trouble like i said in the previous post.
1. I tried to determine which filter should be used, the idea was a suction filter since the pump and the motor both require the same filtration.... but then i read that the suction filter should be above >100 micrometers, and that's much more than i need, so that's no option.
2. Can't find any formula for determining how big the oil tank should be. The only formula i found isn't useful for me.
08/03/2010 4:44 PM
For fundamental hydraulics I would recommend the Fluid Power Design Handbook, published by B&T Hydraulics & Pneumatics, ISBN 0-9653599-0-5. You can find it on line with a used book search. It doesn't cover the myriad of circuits and functions but it is a good guide to start with. There are plenty of other good publications but they will get quite in depth.
For now, do a search for formulas related to the power, speed, torque and flow of hydraulic pumps and motors. Things get a bit trickier when one has to consider often unknown efficiencies, but it doesn't sound like you'll be getting into that yet.
Generally, you will have a large (keep the back pressure to a minimum) return filter for coarse filtration, a suction strainer (rock catcher) to the pump and a 3 to 10 micron pressure filter. If the reservoir and system are properly flushed and cleaned prior to commissioning, you will have pretty much eliminated the chance of getting anything into the pump in the future.
Rough rule of thumb, the reservoir will be one gallon per HP.
Don't forget the cooler. The cooler has to be rated (at a minimum) to remove the heat of inefficiency; e.g., 10 HP system, 80% efficient = 2 HP cooling required.
In my many years I have come to a conclusion that one useless man is a shame, two is a law firm, and three or more is a congress. - John Adams
Good Answers: 18
Re: Hydraulic Calculations?
08/04/2010 7:44 AM
I dont quite know what the capacities of your design is, however, bear in mind that the hydraulic motor is merely the opposite of the hydraulic pump. The pump will have to be driven by something, perhaps an electric motor? In that case you should size the electric motor to do your job. Remember that if you need 22 kw to drive the pump, your hydraulic motor will have to be rated to 22kw. (Nothing saved) The ancilliaries required to keep the lot operational and cool does not warrant the excercise.
Always learning
08/04/2010 12:56 PM
This post contributes nothing at all to the discussion.
I dont quite know what the capacities of your design is, however, bear in mind that the hydraulic motor is merely the opposite of the hydraulic pump. I am sure the OP already knows this.
The pump will have to be driven by something, perhaps an electric motor? Clearly he knows this too -- he is driving it with an engine.
Remember that if you need 22 kw to drive the pump, your hydraulic motor will have to be rated to 22kw. (Nothing saved) I can't be sure what you are attempting to state here, but it is very common to have small hydraulic motors driven my large hydraulic pumps. Perhaps you meant that if you want the hydraulic motor to output 22 kw, then the motor driving the pump must be at least 22 kw plus enough to account for various losses.
The ancilliaries required to keep the lot operational and cool does not warrant the excercise. This is completely untrue. The exercise is educational, and keeping "the lot operational and cool" is an essential part of hydraulic design.
I've marked your post off topic, because it does absolutely nothing to answer the poster's question. His question re filtration is a good one, and a source for confusion with people new to hydraulic systems.
The question is well-answered by Mareng.
Good Answers: 76
08/04/2010 8:09 AM
At the bottom of this past post, I link a reference to some excellent books that will be of tremendious assistance to you.
JavaHead
08/12/2010 9:58 AM
A couple other sources for information:
Lightning Reference Handbook. It is usually published by individual hydraulic equipment suppliers. I see by my two versions:
- Eighth Edition: Berendsen Fluid Power, Inc., Tulsa, OK
- Sixth Edition: Paul-Munroe Hydraulics, Inc., Whittier, CA
Vickers Industrial Hydraulics Manual, ISBN 0-9634162-0-0
08/28/2010 5:04 PM
Hi again.
Sorry I didn't comment anything. Got my hands on some books in the meantime so have been studying those.....
Am still struggling with some things here though....
The pump i have to use on my system has a flow over 500 l/min. Since the system is a part of a vehicle, the info i keep digging out that the oil reservoir volume must be
2-4 * pump flow is just not possible. Am i missing something here!? A 1500 l tank!?
Register to Reply 8 comments
Anonymous Poster (1); JavaHead (1); JohnDoe1981 (2); jvrj (1); KDS (1); lyn (1); mareng (1)
You might be interested in: Micrometers, Laser Micrometers
