Previous in Forum: Differnt Voltage and Frequency Levels Around the World   Next in Forum: What is the Melting Point of Copper?
Stepping Up DC Voltage
08/05/2010 2:19 AM
to step up DC Voltage convert it to AC use step up transformer and again convert to dc
Well i studied about chopper in industrial electronics are they used for stepping up DC if yest at what current and voltages
or any other better alternative?
Please save the power for Next Generation- Do ur bit
Pathfinder Tags: stepin up DC Voltage
Re: stepping up DC Voltage
08/05/2010 2:53 AM
There is a good article about 'boost converters' in Wikipedia.
Good Answers: 11
08/05/2010 4:09 AM
Let me give you some information regarding to choppers.
Yes, choppers are also used for step-up but only DC to DC mostly for DC motors. The most fundamental control of a machine or a process is the ON and OFF control. This scheme of control has two states, the ON stat and when power is removed it is said to be its OFF state.
Now, chopper as the name indicates, is a device which which chopps off the supply in ON and OFF periods respectively.
In other words, we can say that a copper is a kind of switch which allows the power flow in the circuit for a required duration.
DC to DC Converters(Choppers) take input from fixed voltage DC supply such as battery or output of uncontrolled rectifier. The ouput of the chopper is fixed or variable DC voltage and these choppers are normally used in DC drives for controlling the speed of the motor n forward and reverse dirction.
DC motor voltage Em can be controlled downward from the source voltage E by changing the on to off time ratio of the chopper. The average voltage Em
Em = xE
where x is the duty factor of the chopper and is given by x=T1/T2, where T is the cycle time of the chopper.
In the case of step up Chopper.
When chopper is on during T1 the energy from DC generator is stored in the inductor L which is connected to the DC generator. When the chopper is off during T2 the inductor current is forced to flow to the DC power source E through the diode. For steady state operation, there must be zero average voltage across the inductor. Therefore, the postive volt seconds on L during the on interval T1 must be equal to the negative volt-second when the chopper is open.
Therefore, this step up chopper is used to produce a voltage higher than the voltage Em.
When the motor slowsdown the mechanical energy of the load returns to the power source through the chopper this is the so called regenerative braking in which the DC motor operates as a generator.
Other options
http://www.rose-hulman.edu/~herniter/Data_Sheets/LM2577.pdf
http://focus.ti.com/lit/an/slva061/slva061.pdf
http://www.elenota.pl/pdf/STMicroelectronics/3721.pdf
http://www.intersil.com/data/an/AN9208.pdf
http://www.onsemi.com/pub/Collateral/HB206-D.PDF
http://vela.pb.bialystok.pl/~kaie/kaie-md/UP/KA34063appnote.pdf
Re: Stepping Up DC Voltage
08/06/2010 9:57 PM
i think you could use a power inverter. It takes 12 volt dc, and converts it to 110 or 220 a/c power. then, run one wire through a rectifier diode, it should become 110 or 220 dc. I think charles
Register to Reply 3 comments
Anonymous Poster (1); Hameedullah Ekhlas (1); PWSlack (1)
