Previous in Forum: Series Resistance in a mA Trip Relay Test Circuit   Next in Forum: What is Cold Junction Compensation in Thermocouple
Bubbler Systems
08/06/2010 1:05 AM
I want to know the principle of operation of a pneumerstat as used in a bubbler level measuring system. What is its purpose?
Re: Bubbler Systems
08/06/2010 3:15 AM
Back-pressure in a bubbler is one of the many techniques for measuring level. The back-pressure is the head of the liquid. The pressure sensor measures the back-pressure, and the level is inferred from the equation
P=ρgh
Where P is the pressure in the sensor,
ρ is the density of the liquid
g is the acceleration due to gravity and
h is the height of the liquid, i.e. the level, above the bubbler nozzle.
Re: Bubbler Systems
08/06/2010 3:37 AM
That's fine but I want to know where does the pneumerstat fit into all this? What is its principle of operation?
Re: Bubbler Systems
08/06/2010 1:59 PM
I don't know what a pneumerastat is, but a critical component in a bubbler that uses air (pneuma) and is a controller (stat) is the constant flow, differential pressure regulator.
The purpose of the constant flow, differential regulator is to regulate a constant flow rate of gas, because the regulated pressure used to create a constant flow rate will then vary with the back pressure or the head pressure at the outlet of the bubbler tube.
The calculation of level faces the same inherent situation as all head pressure level measurements, an inferred level from head pressure, which varies with the density of the fluid; so a specific gravity calculation is needed for correction.
Anonymous Poster (1); Carl_E (1); PWSlack (1)
