Previous in Forum: Heat Transfer   Next in Forum: Filler Rod for SA213 347H
Wind Tunnel
08/07/2010 11:05 PM
Hi,
Can anyone help me ?
I want to make a wind tunnel with wind speed about 200 km/hr, small size only.
What should the rpm of the fan and what should the other specification required for this matter ?
Thank you,
stanyadji
Re: wind tunnel
08/08/2010 2:26 AM
I doubt there would be just any one answer for this. If the fan section is not much larger in cross-section than the test section, higher rpm will be required than for a larger fan area. I think you will need to calculate the pressure drops through the various parts of the tunnel and then select a fan (perhaps from catalog data) that meets the pressure/flow requirements. I wonder if any duct calculators would go to that high a velocity.
Re: wind tunnel
08/08/2010 6:16 AM
thank you Tornado.
Register to Reply 2 comments
