Previous in Forum: Steam Transposation   Next in Forum: Primary Air Circuit Leakages
Thermodynamics
08/08/2010 3:37 PM
if we have water in vacuum tank and it evaporate at vaper pressure of it according to vacuum pressure.
Is the temperature of generated vapor equal that of water in tank?
thank to all who can help
Re: thermodynamics
08/08/2010 5:47 PM
Yes, if they are in contact they will be at the same temperature. Does that answer your question?
klearzen
Re: thermodynamics
08/09/2010 2:45 AM
Hi, there will be just very little bit different ,
Re: Thermodynamics
08/09/2010 2:59 AM
hi,Vapor pressure means the pressure exerted by the gas in equilibrium with a solid or liquid in a closed container at a given temperature. The vapor pressure is directly proportional to the temperature of the liquid or solid. But there won't be any temperature variation between the liquid/solid and vapor. Its my opinion only i don't know exactly.
Good Answers: 137
Re: Thermodynamics
08/09/2010 5:38 AM
That's about right, but worth adding that the vacuum has nothing to do with it. The partial pressure of the vapour is constant at a given temperature irrespective of other gases present. Also the vapour pressure quoted in the literature is the saturated vapour pressure, i.e. the pressure of the vapour when there is still liquid water present. If all the liquid has evaporated, the actual vapour pressure is less than the saturated vapour pressure. From the saturated vapour pressure you can calculate the mass of vapour present at saturation. If the actual mass is less than this, i.e. unsaturated, the partial pressure is proportional to the mass.
Cheers.........Codey
Register to Reply 4 comments
aws (1); Codemaster (1); klearzen (1); Natarajan (1)
