Previous in Forum: Center of Gravity   Next in Forum: Air Lift Pump
material specification
03/02/2007 11:58 PM
i want to know all material specification.
that is as per indian std ,american std, as per ISO.
And Also
i want information of En....... material property matches with indian std material
Friend of CR4
Re: material specification
03/03/2007 5:20 PM
Any way you could narrow this down a bit? Are there specific materials for which you require specifications? Asking others to provide "all material specifications" is a an expensive task, both in terms of time and monetary cost. Let's start a little more simply:
1) What are you looking for specifically?
2) What methods have you already used to locate this information?
3) Do you have a budget, because most standards have to be purchased?
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
03/03/2007 7:36 PM
The best cross reference of steel I know is "Key to Steel". Look for it in a library. For other materials I always had to check the standards. Some publications like metals handbook and other ASME publications are really usefull. But they won't help you with indian std.
You better narrow your search, because standards are not cheap and have to be purchased, unless you're able to visit a standardization bureau that allows you a local consult. Even in this case, it's better to have pre-defined the informations you want.
Humm... suspicious you are...
Register to Reply 2 comments
