Previous in Forum: Pipe   Next in Forum: I Want to Know How to Design a Transformer
Support Which Allow Thermal Stress
08/11/2010 7:16 AM
i want to support a hot hollow aluminium sphere vessel (inner temperature around 500degree Celsius,outer is exposed to atmosphere)which is carrying a pressurized fluid(around 120bar) with a outer hollow aluminium sphere. how can i transmit the inner sphere load to the outer one ? it must allow the thermal expansion and must by rigid for pressure. visit the following link.. http://www.scribd.com/doc/35711176/support-and-transmit-load
Good Answers: 109
Re: Support Which Allow Thermal Stress
08/12/2010 4:23 AM
Hi,
aluminum at 500°C??? why that? What is inside so you need Al? Which alloy?
Any fluid I know will either react with the aluminum (water) or decompose (hydrocarbons or silanes) or alloy (metals).
Transmission of load is here more precise transmission of pressure.
Let a fluid in the gap be pressurised to the same pressure as the inside.
Give some more details!
This is not a device to play with.
You can easily do a lot of damage to yourself and others!
RHABE
08/17/2010 8:32 AM
thanks for your answer..yes i know it's somewhat dangerous.thats why i'm searching for a perfect design.actually i need a space to allow air with minimum flow resistant in between the two spheres. the inner sphere and then a outer hollow sphere in between these two some space must be there to allow free flow of fluid. the outer sphere acts as a cover,. u can imagine a combustion similar to IC engines takes place inside the inner sphere.thanks in advance.click the following link. http://www.scribd.com/doc/36002470/rigidly-support-a-body-with-thermal-expansion
Register to Reply 2 comments
