Previous in Forum: 230 VAC Compressor   Next in Forum: Troubleshooting Contactors
9 comments
Installation of 500kva dg
08/11/2010 10:17 AM
what is the capacity of copper cable that can be used for 500kva dg?
trivandrum,kerala,india
Good Answers: 170
Re: installation of 500kva dg
08/11/2010 10:26 AM
Typically, 3 Runs of 3.5c & 300 sq.mm YFY Cable
08/11/2010 10:40 AM
size of copper that can be used instead of aluminium
08/11/2010 10:57 AM
Yes! Copper@ If aluminium, it should be 3R x 3.5 core x 400 sq.mm cable.
08/11/2010 10:35 AM
→ British Standard 7671.
Re: Installation of 500kva dg
08/11/2010 10:52 AM
wikipedia
08/11/2010 8:51 PM
Quote EE65 "Typically, 3 Runs of 3.5c & 300 sq.mm YFY Cable"
If that for a generator output of 208 v, 240 v, 415 v, 480 v or 600 volts or some other voltage?
08/11/2010 9:16 PM
OP is from India. In India, 500kVA DG sets come with 415V Output Voltage. So, the cable size given is for an output voltage of 415V, 50 Hz.
08/12/2010 2:07 PM
You should give the current rating shown.in the nameplate.Afterwards decide on type of cable(insulation,single or 4core,method of laying,amb temp,length etc) and by referring BS 7671 you can select.
pnaban
08/17/2010 3:12 AM
750A amps
Register to Reply 9 comments
ampsengineering (2); Anonymous Poster (3); electricalexpert65 (1); pnaban (1); PWSlack (1); wareagle (1)
