Previous in Forum: Laser etching to replace PLU stickers on fruit?   Next in Forum: Using Fingernails to Store Data
How to calculate MD KVA for a plant
07/20/2005 8:18 AM
Sanjay Katkade writes:
Please tell me how to calculate Maximum Demand (in KVA) for a certain project / plant. If the supply frequency is 50Hz and Power Factor is 0.8.
Is it dependent on transformer rating or connected electrical load in the plant?
Friend of CR4
I wouldn't even know where to begin.
07/20/2005 12:11 PM
This is such a wide open question with so many potential variables. There's no way I can even begin to approach it.
Off to take on other challenges. Good luck everybody! See you around the Interwebs.
You need a professional
07/20/2005 3:15 PM
I think you should contact an engineering consultnat to help you make these decisions.
Plant demand
07/21/2005 8:49 AM
The plant demand (power draw)will be based primarily on the connected load. Demand will vary as the load varies. Usually the concern is peak demand which affects equipment sizing and utility billing. Transformers have constant (core) and variable (coil) losses that add to the demand, but typically are less than a few percent of the overall demand. Power factor will vary unless corrective measures are taken. Partially loaded constant speed electric motors are typically the major cause of poor power factor resulting in a higher KVA for a given power draw (KW).
Re: How to calculate MD KVA for a plant
10/12/2007 3:14 PM
Hi
It is totally depend on Plant load and distribution System of Plant.
Ishaque
Anonymous Poster (2); Chris Leonard (1); Howetwo (1)
