Previous in Forum: Fault Current in Substation Grounding Design   Next in Forum: Fire Protection to Generator Room
Total Dissolved Gas in Oil
08/12/2010 12:35 AM
I have a data recording dissolved Total Gas in oil which is measured online (every 15 minutes), but I am confused analyze it, because the profile fluctuates with a fairly large range. I think it is strange because with the added time of the operation of a transformer, the gas content inside the transformer tank should be increased. Is there someone who can explain to me why it fluctuate?
Pathfinder Tags: total dissolved gas in oil
Good Answers: 61
Re: Total Dissolved Gas in Oil
08/12/2010 10:50 AM
If the transformer is a sealed tank, the total gas value should not change drastically. There will be some fluctuation with the temperature of the oil, and the temperature will vary based on the loading, ambient conditions (temperature, day/night, sun/overcast, etc.) and whether or not the forced cooling (fans/pumps) is running.
A vented tank will show more fluctuation, but it should still follow a well-defined pattern due to the solubility of gas in the oil. Higher oil temperatures should lead to lower total gas, and lower temperatures should correspond to higher total gas.
If the total gas is rising, you should do a full dissolved gas analysis and compare it to a previous test. A rise in combustible gases (acetylene, ethylene, ethane) indicates arcing in the oil, and damage to the transformer is likely.
08/17/2010 12:41 PM
thanks
08/24/2010 2:12 AM
Can you explain to me why the amount of gas in the oil decreased with increasing temperature in the transformer oil (Higher oil temperatures should lead to lower total gas)? and please give me a reference that explains this phenomenon.
Thanks
Good Answers: 131
08/12/2010 12:32 PM
If a transformer is healthy, total gas should stay fairly constant (not increasing) unless there are causes to make it go up (heating, insulation breakdown, faults, etc.). Even if it were fluctuation due to changes in loading, temperature, or similar, the "inertia" of the oil mass would damp out any sudden changes.
Have you considered that your severe fluctuation could be a problem between the sensor and the monitoring unit? I presume these are low-level signals, maybe 0-1mA or millivolts, so some sort of damage to the wiring or connectors can cause strange readings. Wouldn't be the first time.
08/17/2010 12:41 PM
thanks
PeterT (1); pwr2thepeople (1); studentkere (3)
