Previous in Forum: CNG Vehicles   Next in Forum: Wheel Cylinder 2003 Windstar
1995 s10 blazer
08/13/2010 12:50 PM
I changed the brake pads on my blazer the brakes would pump up with car shut off but I started the car the brakes went to the floor I then changed the calipers and master cylinder and I am still having the same problems any suggestions
Re: 1995 s10 blazer
08/13/2010 5:07 PM
This has been covered many times here. Did you bench bleed the master cylinder?
Then did you properly bleed each brake cylinder starting at the right rear, then left rear, then right front etc. Longest hose run to shortest?
Have you ever done this before?
Good Answers: 60
Re: 1995 s10 blazer
08/14/2010 1:03 PM
Use the search thing to the right where it says "Search all of CR4" and you get
http://cr4.globalspec.com/search/sitesearch?do=show&sort=textmatchrank&srch=bleeding%20brakes&order=asc
Good Answers: 123
Re: 1995 s10 blazer
08/14/2010 8:59 PM
Did you check the wheel bearings? Did you introduce air into the brake system? Did you screw with the rear brakes? Have you ever done brake pads before?
Bob
bob c (1); lyn (1); peterg7lyq (1)
You might be interested in: Pneumatic Brakes, Electric Brakes, Calipers
