Previous in Forum: Non Destructive Testing - Rolling Friction Evaluation   Next in Forum: Load Testing of Cranes
12 comments
Valve
08/14/2010 4:04 AM
why do we include a check valve and then a butterfly valve at the discharge of a pump??
david_james
Good Answers: 67
Re: valve
08/14/2010 6:55 AM
Which type of pump? What it handles? What capacity/size? Witout these informations answers will be like throwing arrow in dark.
However, the most general answer is- the check valve is meant for preventing backflows from discharge pipe when pump is not in operation. In case of multiple pumps installed in parallal, liquid backflow will be disasterous, as it will bypass some pumped liquid to suction again. Liquid backflow may also cause reverse rotation of impellers in case of centrifugal pump.
Good Answers: 38
Re: valve
08/14/2010 9:27 AM
Pritam gives a correct answer and the best description of the need for a check valve.
However, I would like to add:
- The damage that can occur if reverse flow occurs within a pump includes impeller disengagement (unscrewing the impeller) and seal damage
- It is possible to run A SINGLE PUMP with no check valve and a shutoff valve upstream and downstream of the pump. As stated above, disaster can occur if multiple pumps in parallel without check valve protection.
Good Answers: 101
Re: valve
08/14/2010 7:01 AM
  1. Check valve prevents backflow of liquid.
  2. Butterfly or ball valves isolate the pump when not in use or when undergoing servicing.
Re: valve
08/14/2010 8:12 AM
And to add to the Dark Lord's comment, the Check valve has an occasional malfunctioning capacity (sealing on those times are not 100%).
This creates some problem when you try to take out the standby pump for repair with the other running.
Re: Valve
08/14/2010 9:34 AM
Why indeed. There are numerous applications where a check valve is never required.
And numerous applications where a valve at the outlet of the pump is not required, either.
Good Answers: 61
Re: Valve
08/14/2010 2:16 PM
OHH! Lynlynch,
Please, you are not just going to leave us hanging here like this are you???
Give us some valid examples of a centrifugal Pump Installation where the pump is fully piped into a system but does not need a check valve and or an outlet block valve.
Do it once and do it right
Re: Valve
08/14/2010 7:11 PM
"fully piped into a system" is a horse of a different color.
Good Answers: 101
Re: Valve
08/14/2010 9:48 PM
A submersible pump for an ornamental fountain comes to mind. All it needs to do is to force water up through a series of nozzles to form a spray after all.
Re: Valve
08/14/2010 10:07 PM
PCB fab equipment pulls fluid from a sump and pumps it into a spray bar system to develop and etch circuit boards. Turn the pump off and everything drains back in to the sump.
Good Answers: 48
Re: Valve
08/15/2010 5:08 PM
In fact there are many oem applications for small centrifs (or other pump types), especially closed-circuit in heat-transfer, such as coolers/chillers for lasers, x-rays, semiconductors, etc where there are no valves whatsoever. For pumps in general, type/quantity/location of valves is specific to pump types and applications. There is no general rule, and too many variations to be more specific here.
Pakistan - Member - New Member
Re: Valve
08/14/2010 6:19 PM
Dear All,
WATER WELL, PUMP, & TANK CHECK VALVES
On a well and pump water supply system a check valve may be installed between the incoming water line from the well and the water pump and pressure tank, such as shown in this photograph of a one line jet pump with a check valve right at the water pump inlet.
You can see the check valve as a bronze assembly at the face of the pump, connected to well piping in this photo. (A similar check valve is visible closer to the foundation wall in a different water pump installation shown in the page top photo.)
You'll notice that this is a one-line jet pump system with the inlet or suction line from the well running horizontally from the face of the pump, and the outlet water line rising vertically off of the pump assembly. The pump's electric motor is at the rear of the assembly. (You can see corrosion and leaks on the water line rising from the pump assembly.)
The water pump check valve helps avoid loss of prime (it keeps water from flowing backwards out of the pump and water tank and back into the well when the pump motor has stopped).
Our photos above show a tpyical brass well piping check valve. A spring-loaded internal valve permits water to flow through the valve only in one direction. The check valve helps assure that the jet pump can suck water out of a shallow well - most water pumps cannot move water if the inside of the pump assembly itself is air bound. Atop some pump assemblies you'll see a removable pipe plug which permits water to be poured into the pump to prime it. (DO NOT pour water into or onto the electric motor itself.)
In summary, a well piping check valve prevents water from siphoning back out of the water tank and water pump and down into the (presumably lower) water well when the pump stops running.
A check valve at this location is a great idea and reduces the risk that a failure of the foot valve down in the well leads to inability of the pump to draw water. The foot valve s located at the bottom of the well piping and intended to accomplish the same thing. This is "cheap insurance" or perhaps the foot valve has already failed (or was omitted) at this installation.
Check Valves on Municipal Water Supply Piping
You may see check valves installed on municipal water supply piping too, to prevent possibly unsanitary water from inside a building's piping from back-flowing into and contaminating the municipal water supply system piping during a time of loss of municipal water pressure.
Check valves installed at the right location on water system piping are a good idea and are required by national and local plumbing codes in many jurisdictions.
Check valves are also installed on drain piping such as on some sewer lines (where sewer backups are likely) and on sump pumps (discussed below).
Other Applications of Check Valves on Building Plumbing & Piping
Check valves on sump pumps: Check valves are used in other plumbing applications as well, such as on sump pump drain lines to prevent back-flow of water from the sump pump exit piping into the sump pit when the sump pump turns off.
Regard's
AUR
Good Answers: 76
Re: Valve
08/16/2010 3:30 PM
When copying someone elses work in its entirity, especially when it's copyrighted, please cite source:
© Copyright 2010 InspectAPedia.com, All Rights Reserved.
And, as I've stated before, it is probably not a good idea to copy copyrighted material at all, and rather just provide a link:
http://inspectapedia.com/water/CheckValves.htm
JavaHead
Register to Reply 12 comments
adeebulrehman (1); Anonymous Poster (1); DVader1000 (2); Holzfeller (1); JavaHead (1); lyn (3); MJCronin (1); PennPiper (1); pritam (1)
