Previous in Forum: LED Lights   Next in Forum: IBR Inspector
Domino Printer Pump High Operating Speed
08/15/2010 12:42 AM
We have 4 Domino printer A200 Series and 5 months ago one pump was replaced due to fault "Pump Overspeed". Now we are experiencing the same problem, can anybody help me analyze the root cause of the problem?Is there a problem with the pressure transducer? Or the gutter filter, main filter clogged already?
I appreciate anybody who can help me rectify this problem. Thanks.
Re: Domino Printer Pump High Operating Speed
08/15/2010 7:45 AM
Contact the manufacturer directly.
08/16/2010 4:43 AM
Guest - this same post with this image and message is used over and over again and is becoming irritating. It adds no value or knowledge to the forum whatsoever.
So why waste your time posting it?
Good Answers: 48
08/15/2010 4:27 PM
The fact that the second pump ran for 5 months before the problem recurred indicates that the problem is pump-related (not necessarily the pump itself!), since a system problem would not have been immediately cured with a pump change. Are you using pigmented inks? Whatever; best to consult Domino or their distributor.
Register to Reply 3 comments
You might be interested in: Printer Repair Services, Printer Mechanisms
