Previous in Forum: DP TRANSMITTER ABOVE TAPS   Next in Forum: What Does MODBUS Stand For?
Hobbies - Fishing - New member but have interest and some experience in fishing.
Some Questions about Igniter of Gas Turbine
08/15/2010 4:51 PM
Hello,
I have some questions about Igniter of Gas Turbine. There is a Gas Turbine, it's kinda old though, that has two Igniters intalled whose Igniter's rod will move back when it's running, and go inside when it's being started and after it's started, they will come out by itself. That's for protection of igniter's tip.So my questions here are:
  • What causes the movement of the ingniter's rod?
I am wondering if it's the pressure or Temperature. I don't see anything that deals with temperature, am not sure though.
The second thing I want to know is about the resistance of the igniter's central conductor. Some igniters have a resistance in Mega Ohms and still they work, and some have no resistance at all, when measured from back connection to the tip of igniter.
  • Is there something in igniter for saftey for other reason that causes the resistance?
One of my senior told me this kind of igniter is provided with a DIODE to convert the AC voltage into DC, which will improve the ignition.
I'll be thankfull for your help.
Screamingsilence
Re: Some Questions about Igniter of Gas Turbine
09/29/2010 7:34 AM
Hi,
I have worked before this type of gas turbubines make Mistubusi M701D model.For safety concrin of ignitor its move back after ignition.It done by Pneumatic clyinder with ignitor.Due to combustion chamber temp is more than 400deg c and combustion shell pressure is 20 Barg.
For igniotor resistance you use analog multimeter with high in put impendence.and disconnect field wires of igniotr than measure its resistence.
09/29/2010 9:23 AM
Hi,
Thank you for you reply. What I can understand now is that there's a cylinder built-in in the ignitor and it takes pressure from the combustion chamber and moves the ignitor off of the hot area. Please correct me if I am wrong.
Thank you.
Screamingsilence
09/30/2010 7:55 AM
Hi,
It is a single acting pneumatic clyinder with operating pressure 5 barg and movement control by Solenoid valve.Normally sov de energized amnd clyinder postion not in combustion chamber.when GT controllers give command during fuel opening time sov operate and clyinder moves in to combustion chamber and iginte 30 sec or 60 sec depending of GTG fire tuning.
There is no any connection of ignitor form combustion chambers except its mounted on chamber body.
10/17/2010 4:18 PM
Thank you so much for helping me out.
What I am confused about is, the one installed at the GT in our plant has no SOV connected to it, neither is there any tubing that could supply instrument air to the Single Acting Pneumatic Cylinder you told me about. It works just they way you told me, though. The Ignitors' Cylinder has no tubing but an Electric Supply for the spark plug.
What I can guess is that it's the pressure of the Gas in the Combustion Chamber that operates the Cylinder.
I hope you got what I am trying to say.
Screamingsilence
Register to Reply 4 comments
