I agree with Orval. That is why I subscribed. I am an artist with an idea and no material to bring it to fruition. Warning, I am a small contractor...very small.
There has to be a material out there somewhere that can be painted and used as a reservoir liner.
I am designing natural swimming pools and need a flexible liner that can be painted to agree with it's environment. So far the only thing on the market is pre-stamped liners that bear little or not resemblance to the bottom of a pond, or stream or anything in real life. I live on the Atlantic Seaboard and have never swum in a square aqua blue hole in the ground.
This material needs to be as flexible as a .45mil rubber pond liner, and be able to stand up to mild non-chlorine based pool chemicals. It needs to be seem-able so that it can be fitted to irregular shapes on site, and painted to resemble it's surroundings. The paint must be able to withstand some abrasion in areas where there are shallows. Presently Krylone makes a paint that adhears to plastic, but it does not hold up on rubber under water with testing.
Pond liners will work quite well but are black. Do they have to be BLACK? Can vinyl sheeting be purchased before it hits the "lets dye it all blue" manufacturer? Can it be designed at that stage?
Of course, cost is prohibitive, which is the other portion of the problem. The last estimate I was given for an inground natural pond was so high it was embarassing.
I am trying to reach the real market, not something only the Getty's can afford. I believe there is a very good market for this type of landscaping indeed, and would appreciate any help I can find. Thank you for taking the time to read this, I know you are all busy. Diane Upton, Upton Studios LLC.
