Previous in Forum: GI Strip for Earthing??   Next in Forum: Generators and Transformers' Breaker Sizing
Problem With REL 511
08/18/2010 2:58 PM
Hello Everyone,
We have a distance protection relay of ABB REL 511 v 2.5 on a line from substation to another
but there is a problem with it as follows:
the relay did not make any trip with any fault.
i have read a new configuration from another good tested relay and put it on this relay.
but the same problem.
dose any one have soluotion for this problem???
thanx 4 help
Proudly I am MUSLIM
Re: Problem With REL 511
08/19/2010 12:51 AM
Sir
Please test the relay for both forward and reverse zones.
May be a problem with direction.
Raju.S
08/19/2010 1:36 AM
What were the commissioning results? Also I have found out problems may appear because of the communication system. I had some problems with autorecloser reactivation because of a SCADA system communication problem. More over, did you check the current and voltage transformers?
The time is ......now
08/19/2010 4:59 AM
ABB.
08/19/2010 10:21 AM
thnx to all for helping.
but the relay did not make any trip neither forward nor reverse or over current.
and i checked the setting and configuration
and downloaded it from a healthy relay
and i did not need any communication to test the distance scheme
Proudly I am MUSLIM
08/21/2010 12:08 PM
Sir
which kit u are using for testing?
do you expect any problem in the output relay u are selecting to trip the kit.
are u able to read current while testing from the relay.
Please check pt fail logic is preventing the trip
regards
raju
07/19/2011 6:09 AM
Hi moody
If you can send me your settings I can have a look for you...I left another message on CR4
Greetings
Mike
CR4 Admin - email address removed
From the CR4 Rules: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses. You can share this information via the CR4 internal messaging system.
Register to Reply 6 comments
Anonymous Poster (1); MJ Jordaan (1); moody (1); nikolay (1); rajukailas (2)
