Previous in Forum: Motor Winding Heater Kit   Next in Forum: Problem With REL 511
10 comments
GI Strip for Earthing??
08/18/2010 2:46 PM
Hi, I have to replace copper conductor used for lightning rod earthing by GI STRIP, I want to know, what is the Equivalent GI strip dimension for a 95mm2 copper conductor earthing?? Some people advice me 50X6mm GI...but could you please give me a solution for this? Is their any conversion table between Copper and GI??
Pathfinder Tags: earthing GI strip
Re: GI Strip for Earthing??
08/18/2010 8:55 PM
Generally, I don't think there is any conversion tables between Copper and GI. GI is a Galvanise Iron where the iron have different chemical composition. There can be low carbon with high silicon or low carbon with low silicon and there is many grad of iron in the market. Each of the iron grad have different conductivity for the current passing thru it.
In china GI strips is very common used for earthing but there is only one problem. When the GI is grounded in to the soil the tendency is that, these GI plate will get corroded over the years and you will have a very bad earthing for your electrical services or for your lightning rod.
08/19/2010 12:55 AM
u can send me ur email i hv a excel sheet to calculate these things
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
08/19/2010 1:19 AM
please gives us the link it will be very useful
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
08/20/2010 10:09 AM
From the Site FAQ: Do not post phone numbers or email addresses. The CR4 Admin will delete all phone numbers posted in threads or comments, and we strongly urge you not to put up email addresses.
08/30/2010 2:56 AM
shailesh.tu@gmail.com
please send the excel file..... i have to verify design and i dont have any documents related to it.
also if you find time send data regarding substation earthing design
02/14/2011 4:21 AM
What is the weight( Kg) of 25x3mm / meter G I Strip?
Good Answers: 170
08/19/2010 10:53 AM
S = I x Root 't' / K
Where,
I is the maximum earth fault current anticipated, in amperes
't' is the fault clearing time or the fault duration, in seconds
K is a constant (for GI it is 80 for 1 sec. fault duration and 46 for 3 seconds duration)
S = Cross section of the earthing conductor, in sq.mm
Hope now you can calculate th GI Strip size required
08/20/2010 10:08 AM
Thank U Sir!!!
08/20/2010 10:17 AM
sir,this is for earthing the 'Building Lightning arrestor'...is there any predetermined standards or calculation ???
08/20/2010 1:17 AM
give me ur email id i will give u
Register to Reply 10 comments
Anonymous Poster (3); electricalexpert65 (1); nadim7862 (2); Simon Wan (1); sms149 (1); STHALASAYANAM (2)
You might be interested in: Metal Strip, Stock and Strip Feeders, Strip Heaters
