Previous in Forum: Phase to Neutral Voltage   Next in Forum: Cable Selecting
Wire Size VS Amps
08/19/2010 8:30 AM
hi gents
does any one of you guys has standard chart for wire size ampacity, i already google it and found some but different from each other.
i am looking for standard chart which i can use it to do electrical installatios.
if you dont have it, would you pls advice me where to find it.
realy appreciate your help
thanks
Re: wire size VS amps
08/19/2010 8:31 AM
It's still all in British Standard 7671, and has been for years.
In the UK, most installations require trhe issue of a test certificate under the Building Regulations Part P. The nature of the question indicates the original poster does not have sufficient training and experience to carry out correct installations in the UK.
If in doubt, consult a qualified electrician.
Re: Wire Size VS Amps
08/19/2010 1:17 PM
Good Answers: 804
08/19/2010 7:39 PM
It depends on where you are. North America, use the National Electric Code (or Canadian Electric Code). If you are outside of North America, use the BS (British Standards) or IEC standards for wire ampacity. All of these standards will vary by application; where is it used, how it it used, what is the temperature, etc. etc. Nothing else is relevant.
08/20/2010 1:40 AM
Here is a nice "generic" wire gage table, along with a voltage drop calculator:
http://www.powerstream.com/Wire_Size.htm
08/22/2010 9:38 PM
it depends upon which standard you are using..their differences lies in the distribution system they have..215V or 110 V (talking about AC)...it'll be best if you adapt standards applicable to your country...mine, I'm using NEC standards and some of its counterparts...another helpful chart will the chart by OEMs..
take care of your seconds and the minute will take care of itself..
JRaef (1); pantaz (1); PWSlack (1); rockraiden (1); wareagle (1)
