My 8-year-old twins are doing a project for their science fair at school. I had some sections of pipe and a couple of valves on hand from recent repairs I had made, so I thought maybe they could use these as a starting point and as examples of how freezing water can cause damage. Does anyone have any suggestions on where I can direct them to find information on their level that would help them to explain this effect. One of the valves I removed was a ball valve rated at 600psi. The ratings of valves are usually a fraction of their actual failure points. I'm wondering if there is somewhere I can go to find information on how these valves are rated and if we can include it in their report as a demonstration of the amount of force generated by freezing water. Also, does water continue to expand as the temperature drops below freezing? I have noticed that the calls for repairs of frozen pipes generally only come in when the ambient temps drop below around 15 degrees F.
