Previous in Forum: Earth Resistance Testing   Next in Forum: Soft Starters for Fans/Pumps
Ampacity
08/19/2010 11:01 AM
With a load rated 460kW, 480v, 3ph., would using (3) 4/0 THHN wires per leg @ aprox. 80' distance, (in conduit) be sufficient w/ a max. 700 amp sorce output? I say yes, some say no. I may be missing a calculation factor. Not sure.
Re: Ampacity
08/19/2010 12:33 PM
→ British Standard 7671.
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAArgh!
Re: Ampacity
08/19/2010 1:14 PM
460 kw/0.48 x 1.730 x 0.79 pf = 700 amps. From table 310.16 NEC
4/0 thhn ampacity = 230 amps x 3 ckts = 690 amps assuming 3 ckts in 3 separate conduits. 4/0 is not large enough. Is this a continuous load(over 3 hrs)?
If load is continuous you need to use 700 amps x 1.25 = 875 amps
Require 3 ckts of 350 thhn or 4 ckts of 4/0 thhn. Are you using NEC table 310.16
Juzdatech please reply to this post.
Table NEC 310.16
http://www.houwire.com/products/technical/article310_16.html
Re: Ampacity
08/19/2010 1:50 PM
Thanks wareagle,
Yes I was using the same chart, but out of the Uglys Elec. References book (2008). I actually used the 90degC chart @ 260A. I am a tech that was ask my input on this and will not have the final decission. This is an AC Drive feeding a Dyno. The wires actually existed for a 500kW, but was never powered up so it was questionable. It is YTD if it will run continuous or even hit full capacity.
Your reply was helpful.
Re: Ampacity
08/19/2010 2:52 PM
You can not use the 90C rating when making this calculation. It is only used when derating the conductor for temp and number of conductors in conduit.
Re: Ampacity
08/25/2010 2:41 PM
Will someone post the document titled"nec conductor sizing.htm" for the benifit all readers?.
pnaban
juzdatech (1); pnaban (1); PWSlack (1); wareagle (2)
