Previous in Forum: Quiescent Chambers   Next in Forum: I wonder how much more of this goes on in the UK ?
Quiz Board Creation ~ Help Wanted
08/20/2010 2:00 PM
I want to make a quiz board for the kids at the church so they can see who pushed the button first. All I got is 4 220v contactors and push buttons and 4 lights. I tried all possible ways that I can think of. Each contactors got 1 NO and 1 NC.
Is it possible, or should I stop trying?
Re: Quiz Board Creation ~ Help Wanted
08/20/2010 5:07 PM
Are you going to hook this up to 220V?
08/21/2010 5:43 AM
YES I'M GONNA USE 220V. I CAN ONLY GET 2 CONTACTORS CANCELING EACH OTHER OUT BY USING THE NORMALLY CLOSE TO BYPASS THE NEUTRAL OF THE ONE AND THE LIVE OF THE OTHER. I'M SURE THERE IS A WAY.
08/21/2010 2:52 PM
Maybe that's why they call this game "Jeopardy"!
I think I found a way to do it if the relays each had one NO and two NC contacts; haven't yet been able to get it down to one NC.
08/22/2010 2:05 AM
ok thanx a lot.
Popular Science - Cosmology - New Member Engineering Fields - Civil Engineering - New Member Engineering Fields - Nuclear Engineering - New Member United States - Member - New Member
Good Answers: 38
08/23/2010 4:59 PM
I'm sure there are people out there who are better versed in discreet mathematics than I and while there is some "minimum" number of contacts required, the minimum isn't always the best idea. The wisdom I was taught was to have separate contacts for each logic statement you wish to make.
In this case
1. If button one is pressed and (not 2 or not 3 or not 4) then light the bulb.
2. If button two is pressed....
Therefore, I would use the relay that has at least one NO and at least 3 NC contacts.
Again, there may be a more elegant solution, but this was the "rules to live by" I was taught.
Sometimes my thoughts are in a degree of order so high even I don't get it...
Anonymous Poster (1); ChaoticIntellect (1); FRIKKIE (1); kramarat (1); Tornado (1)
