Previous in Forum: Installation of Positive Displacement Flow Meter   Next in Forum: Natural Vibration
Tank Baffle Plate
08/23/2010 4:52 AM
What is the purpose of tank baffle plates welded to the circumferential wall of atmospehric storage tank with vertical agitator? Thank you.
Re: Tank Baffle Plate
08/23/2010 6:29 AM
Any baffle is put to break the stream line flow there by agitating the fluid, It also increases the effective surface area.
Both these effect increases the heat exchange effectiveness,
08/23/2010 8:58 AM
One use of a baffle is to prevent any form of vortexing to appear when the agitator is activated.
08/23/2010 9:11 AM
.....and thereby increase the effectiveness of the agitation as compared to an unbaffled tank of the same geometry and configuration of agitator.
Good Answers: 58
08/23/2010 9:14 AM
Baffle plates are used in some semi trailer and straight truck tanker applications to preserve vehicle stability when accelerating or braking. The plate somewhat (depending on design) prevents sloshing of the product while in transit.
Anonymous Poster (1); KJK/USA (1); PWSlack (1); vanuta (1)
