Previous in Forum: Reinforced Cencrete Base Slab   Next in Forum: Capturing Wave Energy
29 comments
How to Constuct Road on Soft Soil/Clay?
08/23/2010 5:30 AM
I have a problem in road construction on soft soil/clay, the road has been constructed using gravel on soft soil, however, when rain comes, and the loaded truck of 20-30 ton pass the road, the gravels are buried, and the road is corrugated (there are excessive settlements). I was wondering if vertical drainage will help the problem, but I have no experience in the application. any way, will vertical drainage help my problem? or any other alternatives? (sorry for poor English, hope you understand my problem)
Pathfinder Tags: soft soil road construction
Re: How to Constuct Road on Soft Soil/Clay?
08/23/2010 7:12 PM
I'm not an expert on road construction. Road construction in this country requires much engineering. You just can't lay down gravel over a soft bed and expect it to hold up under a 20-30 ton load whitout it failing. It requires engineering to design a road that will last. Drainage is a big part of it, but also the materials used. Roads here are mostly paved with either asphalt or concrete and can cost upwards of a million dollars per mile to construct. If your country has an abundance of bamboo; that can be used to make some pretty good roads if woven into mats and covered with sand and gravel, but it needs to be placed above the soft sub-strait.
Mr.Ron from South Ms.
Location: No.6 Industry Yard, Tuanhe South Village, Xihongmen Town, Daxing District, Beijing, China
09/12/2014 12:02 AM
Dear Sir,
We are a professional manufacturer of composite product, which is located in Beijing, China, established in 2001.
The main products are: SMC/BMC manhole cover, FRP/GRP manhole cover, lawn manhole cover, tree gratings, water gratings, gully gratings etc.
If you are interested in any of our products, please don't hesitate to contact me, we assure you of our best service at all times!
Best regards
Phoebe
chaocai@fydt.com.cn
Life is full of ups and downs
Good Answers: 151
Re: How to Construct Road on Soft Soil/Clay?
08/23/2010 11:27 PM
For 30 years, I lived on and was responsible for maintaining such a road in the New England region of th US. I didn't build this road, I just inherited it. Every Spring, with the thaw the road would turn into quicksand and literaly swallow up cars. Come May the road was a washed out rutted mess that one could barely drive a car over. Grading and adding gravel made the road passable for the year, but the following Spring the same thing happened.
I consulted with a number of contractors and engineers but I could never get an affordable and reliable solution. Meanwhile the other residents were pushing me to pave the road. I had a difficult time convincing them that his would be throwing a lot of money away. Unless the sub base of the road was sound, the pavement would not last but a few years.
Finally I was put in touch with an old time contractor with a lot of experience building gravel roads. His assessment was that drainage was the primary problem. Our problem was twofold. First the road was constructed with a thin layer of sand and gravel placed on an impermeable sub soil. The second was that we plowed the road in the winter. This allowed the soil under the road to freeze deeper than the surrounding margins that were insulated by the snow banks.
Come the spring thaw, the snow banks melted back and the margins quickly thawed. But the deeply frozen road base acted like a dam, forcing the natural ground water to flow over it and through the top layer of gravel. This is what converted the surface into quicksand.
His solution: First dig up the road and replace the sub surface of sand and clay with crushed gravel that would not become compacted. The next was to construct drainage ditches on either side of the road with culverts under the road that would allow free drainage of the ground water.
It was expensive, but not as expensive as paving the road with asphalt. The whole reconstruction took three years, but the road has stood up now for the past ten years with minimum maintenance.
Bottom line: drainage is everything. It is the subsurface flow of ground water that causes the major damage to a road, paved or gravel. Water has to flow freely. When the road becomes a dam, the water is forced to the surface where it creates the washouts, pot holes and quicksand.
08/23/2010 11:55 PM
Consider a geotextile fabric under the rock. The fabric keeps the rock and soil from mixing and creates a very stable base. The fabric can complicate grading operations if the fabric is uncovered or torn with the grader.
08/24/2010 3:07 AM
What is the surrounding area like? Are you going through a swampy area, on a slope, in the bottom of a valley?
08/25/2010 2:44 AM
It is in swampy area and near beach, and also with very high rainfall rate (heavy rain falls very often, the frequency like one day raining and one day no rain and takes a whole day). I am in south borneo, Indonesia. Another problem is the ditches are easily get shallow.
08/25/2010 2:51 AM
It is in swampy area and near beach, and also with very high rainfall rate (heavy rain falls very often, the frequency is like one day raining and one day no rain and takes a whole day). I am in south borneo, Indonesia. Another problem is the ditches are easily get shallow (the fines material like mud on the road has been swept easily by rain to the ditches)
08/24/2010 4:35 AM
Google and read up on the works of "John Loudon McAdam " - best advice.
jt.
CR4 Admin: Part of this post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
08/24/2010 7:16 AM
Has nothing to do with the discussion!
08/24/2010 8:52 AM
Crushed stone with 100% fractured faces is your best friend. This is the best way to stabilize a soft area. Drainage would help but it may not be feasible to drain tight soils, so replace with crushed stone. The deeper the mudhole the bigger the stone. 100% fractured faces is key, bank run or river gravel that is rounded will not work very well. If the soft area is deep, use primary crusher run to bring it up to within a couple of feet, then go with 2 inch minus. You can use geotextile to replace up to a foot and a half or so (40-50 cm) of hard fill.
Never underestimate the power of stupid people in large groups.
08/24/2010 9:16 AM
Ever build a road through a swamp like that?
08/24/2010 2:20 PM
Never said it would be cheap or easy, but if he has access to crushed stone that is the best way.
08/24/2010 3:08 PM
Best way or not that is not how it is done if you wish to be successful.
RCE seems to know what he is talking about.
08/24/2010 9:58 AM
Regards,
I have had situations like the one you are describing. There is a cloth that you can use that 'spans' the soft areas. It looks like the plastic bags that replaced burlap bags. The fabric is made of plastic strands and it comes in rolls 20' wide. Be prepared to spend some money! But if you put this down on a prepared subgrade and then top with limestone 2" you should be able to keep the road's profile.
I have seen it used on a field with no base installed and the fabric was laid, and covered with two inches of stone. It is used now for a sawmill's log storage, large trucks, loaders are on it all day and it doesn't give!
Otherwise you will have to keep pounding stone into the soft ground until you 'find bottom'
One blacktopper told me he would cross a swamp with the cloth, put 5 inches of black top for a road -and guarentee it's use! (and that's a statement)
Good luck,
Thom Rogers/babygrapebooks.com
08/24/2010 11:22 AM
Your 'blacktopper' must have had a vivid imagination as there is no way the statement was correct.
Good Answers: 179
08/24/2010 11:14 AM
You would be best served by installing a Geogrid such as a copolymer plastic grid made by Tensar, or an equivalent product, first laid down on the prepared clay soil subgrade, then followed with a fairly thick compacted subbase course of well-graded and drained gravel. IMHO don't just install a geofabric over the clay because it will deflect and possibly tear...eventually you will have severe rutting that mirror images the displacement of the clay subgrade below. Using the Tensar Geogrid acts like a snowshoe helping to disperse (spread out) vehicle wheel loads plus it keeps the subbase materials from migrating into the clay subgrade.
To determine the proper geogrid material as well as the subbase gravel material and thickness is going to take the expertise of a qualified Geotechnical Engineer, who may have to perform field and laboratory soil testing. Please hire the services of such a professional.
Good luck with your road!
08/24/2010 1:27 PM
Oh by the way Geogrid has huge holes through it so it doesn't stop migration of fines in to the coarser rock, filter fabrics like 140n are tyopically utilied for that purpose. Some Mirafi (Mirafi is more commonly utilized as the industry standard or equivalent) geotextiles can perform as reasonably to provide some minimal filtering capability and provide the tensile strength (500x and such), but Geogrids will only filter object about the size of cobbles. Plus these are only used to replace older process of using a subbase material of sand and gravels graded to perform like a filter and provide stability. A good 1-1/2 inch subbase below the road structural section at 90% relative compaction can provide a reasonable surface to build a road structural section upon, and if graded properly drains well. You need to look at the D85/D15 and D50/D50 gradation relative to the gradation of the clay.
Good Answers: 179
08/24/2010 2:54 PM
A couple of the Tensar and ARMCO (and few others) geogrids have very little or no openings in them, thereby negating soil migration.....check them out. I've even used open geogrids through swampy areas here in upstate NY, and in LA, MS and up and down the Big Muddy in 3 different USACE Districts (when serving with the USACE) without a fabric such as Mirafi 140N (a good product, but not an end all and be all...usually "punches down" and mirrors the wheel rutting lanes in and under the pavement....also, not the best material for spreading out wheel loadings either....it is best paired with a polypropylene plastic Geogrid with little or no openings in it's Matrix) and could literally walk on the mud and water... migration of stone subbase was absolutely minimal and later in no way detrimental to structural stability of roadways, levees and other structures above it.
Of course all designs were by a Geotech Engineer and not just any engineer "winging it" without actual field and lab testing so as to ascertain the actual site specific Insitu soil conditions, such as Plasticity Index, shear strengths, etc.. Not one design approach nor "what the last guy got away with" approach can be applied to each and every condition encountered, regardless of what one's Engineering experience and credentials are. Everything is, and must be, performance & economically based, with these two parameters balanced based on a good number of important factors as well as good engineering judgement and design experience. That is why I have lots of misgivings and doubts about federal & state DOT mandated "cookbook" approach to soils engineering and building highways, which in many cases can result in short-lived and under-performance (ie life cycle). That approach is sometimes engineering overkill, sometimes not, but always costly to the taxpayer......and in my experience with state DOT's their design philosophy often results in substandard road surface and subbase performance. My God, all you have to do is look at the current state of dismal Interstate conditions, state by state, and you will concur. And the state secondary roadways are even worse!
Enough said. I know that they'll be many here that disagree with my statements and assessments, and then again, many others will agree with me. Let the arguments begin!!! Nothing like a causing a cockfight, eh???!!!!! ***GRINZ***
08/24/2010 4:12 PM
I would agree and that is why when I started out in Geotechnical and Environmental Engineering, my principals required me to work as afield engineer doing everything the technicians had to do, working on drill rigs logging, forensic investigation of other engineers/contractors failures, and dealing with field changes for encountered conditions during construction. That way when I would write a geotechnical engineering report or a clean closure workplan, or something similar, I was familair with how the testing would be conducted, how investigations data would compare to the conditions encountered during construction and all the problems that develop.
Also, 140n is just a filter fabric not meant for tensile strength, it is typically employed to encapsulate drain rock.
As far as Geogrid, I have a flyer from Tensar here where they have been trying to convince more engineers to spec them instead of mirafi (industry standard). The Geogrid is the plastic straps that are bonded in a perpendicular web, large hole in geogrid. You can bond non-woven or woven geotextile fabrics to the geogrid, we use something similar in asphalt pavements, but this is not the geogrid itself and is a special order above and beyond standard geogrid. I think you are describing geotextile fabrics, which have a much lower transmissivity than filter fabrics, but can retain soils. Geogrid have become the new rage amongst many of the newer geotechnical engineers i deal with on roadways, however, the depth to develop strength and the benefits doesn't usually offest the cost, and i have seen a number of them fail (the engineers typically attribute the failure to installation problems such as excessive lateral pressures when installing fill above the grids. Both the fabric and geogrid depend on building tension to strengthen the soil mass above them, thus they rely on soil interface friction across the weak areas to allow the downward pressures to transmit across the grids as tension (they can not pull out or they fail). Usually it is just cheaper and better too use a aggregate subbase or lime treated subgrade to stabilized the base, and typically cheaper as the materials tend to be cheap and local and the labor is easier and cheaper since it is a simpler process with less likelighood of installation mistake. I had to investigate a $1 million retaining wall where the geogrids mobilized, and once they start moving in clay the thixotropy allows them to slide more rapidly and easily afterwards. As a rule we apply geotextile fabrics here subbase would be way too deep, in areas of localized minor pumping, etc. where we have something stable to attach to through soil interface friction.
08/24/2010 11:46 AM
As a Civil Engineer responsible for design on municipal and State roads, we typically we would increase the aggregate base section or lime treat the subgrade clays. Use a Class I aggregate base. Aggregate base rock will be a crushed rock with some amount of fines in it to act as a filtered material to stop the migration of fine soils up into the base rock section. Unlike clean gravels though base rock requires compaction to at least 95% by ASTM D1557 in the structural section of a Road. Geotextiles do not work very well if the entire subgrade if moving, as they must develop tension across soft areas by extending across firmer areas. Also, Geotextile Fabrics require at least 1 foot of cover. Geogrids typically require about 2 feet or more of cover to develop effect strength in the covering soils. The other alternative to strengthen the soil directly, increase permeability and save some money is to lime treat the subgrade. Mixing lime with the Clay soils and hydrating it forms a stronger subgrade on which to build a road surface. This is much like using a subbase section in your road structural section. Once you have a structural section built then you can cover it with aggregate if you want to help control dust.
08/24/2010 11:49 AM
GA RCE - someone that has experience with the problem.
I saw a section of road go through a swamp in Trinidad - they excavated deep and did about what you suggest. All flyovers were stabilized with many sheet piles as I remember.
08/25/2010 3:13 AM
what do you mean by lime treat? Is it cheap method? how much the cost will be if I apply it for 1 km road of 15m wide? Any reading references or link that I can obtain more information for this method?
08/24/2010 12:03 PM
My family has been widely known for our road building skills for over 150 years. This may not work in your area.So use these posts to learn the questions to ask the guy in your area that does know. Here in claylike, silty soils, we build our roadways across swampy areas much like the Romans, with a high tech twist. We start with woven geotextile fabric followed by a bed of surge, #1(1 1/2"-3") or #357(! 1 1/2"- 4" stone. This will provide a drainage base and spread the load. This should be covered by a layer of #57 (1/2"- 1 1/2") stone and topped with a non graded stone we call #250/Crusher run or #21-A or pug mill. To be stable you must keep the water out as much as possible and elevation is the only way to do it. Build the road on top of not in the swamp. Use material that will spread the load. Anything worthwhile is worth doing right. If you just patch it. You are just pissing your money away and delaying the cost of doing it right at an even higher cost.
libertyheavy
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
08/24/2010 2:20 PM
You could alway get some Mo-Mats from army surplus. The Army used to use them to make roadways and airfields in swampy areas from WWII through present times.
John J Baker
Good Answers: 146
08/26/2010 7:54 PM
The classic road over swamps, and still popular in the north, is the corduroy road using local materials (logs). As the wiki says, you can use a structure of this type as a basis for other surfacing - your gravel and so on.
The logs-across-road design provides a foundation for traction and also has some natural drainage characteristics - allows water to drain off the road, and of course, raises it above the swamp level.
incus opella
08/27/2010 6:59 PM
nice!.. but how about the decay of the logs?
Good Answers: 146
08/27/2010 9:14 PM
I guess that depends on the type of log and also the pH and other characteristics of the water and soil. In the northern bogs, spruce wood doesn't break down too fast.
In Italy the European Alder (Red Alder, Alnus glutinosa) was used for various kinds of construction in water, because the wood is very resistant to decay under water.
Local builders' knowledge will tell you whether there is a type of tree in the area that's very suitable for resisting decay in water and in those soft clay soils.
Of course, if you can get the high tech materials, you won't need to worry about decay and your road will be more permanent.
The corduroy roads are good to support traffic for temporary activities (like logging) and when the work is over, the road is left to break down naturally. For long term use, some repairs or replacement will be needed (in our environment) after ten years or so - maybe longer if there's a surface on top. I don't know how long this road would last in a tropical environment.
incus opella
01/17/2011 12:16 PM
We are an Australian based company specialising in soil stabilisation especially clay based roads. Our chemical changes the molecular structure of clay to repel water. For more information visit our website www.claycretestabiliser.com
01/17/2011 12:26 PM
Are you saying it changes the molecular structure of clay minerals. Seriously? This I would have to see (though I susepct that statement is a marketing ploy). Or is it a pozzalanic reaction with the clay, like lime treatments for road bases or the organic stabilizers made from pine tars.
Register to Reply 29 comments
Anonymous Poster (4); artsmith (2); bakerjohn (1); CaptMoosie (2); civil_spirit (3); gringogreg (1); InventiveFarmer (1); JDknut (2); libertyheavy (1); Phoebe Liu (1); RCE (4); ronseto (1); russ123 (6)
