Previous in Forum: Service Manual of Hydraulic Crawler Crane   Next in Forum: Grade of SS Wire?
Thermoacoustically Driven Pulse-Tube Refrigerator for Gas Turbines
08/23/2010 10:01 AM
This link shows how natural gas can be liquefied at 92K using thermoacoustics:
http://www.springerlink.com/content/h7662031801p8l83/fulltext.pdf
A portion of the NG is used to drive the hot reservoir, but works without moving mechanical parts.
Can this refrigeration method be used to condense out unwanted vapour from g-t inlet air in high humidity areas - driven by the turbine exhaust heat?
Re: Thermoacoustically Driven Pulse-Tube Refrigerator for Gas Turbines
08/23/2010 2:26 PM
This is a long shot, but I knew a VP of Research at JBL Labs who was working on this concept under a contract with NASA. Seem's it might be a good way to cool lots of things. This was 20 years ago.
Harmon Industries is, or was, the parent company. They may have published something.
If this is something you would like to pursue, PM me and I'll give you his name.
08/24/2010 5:27 AM
Thanks for the offer, lynlynch.
As I'm not in a position to implement such a design I don't think it's appropriate to bother the guy you mention. I'm just intereted to know what other engineers think of using this tech on heat engines.
08/25/2010 11:49 AM
There's a local company in Troy,NY that makes this kind of stuff. They're called QDrive.
Charlie don't surf.
Register to Reply 3 comments
lyn (1); Sheps (1); stevem (1)
