Previous in Forum: Thermoacoustically Driven Pulse-Tube Refrigerator for Gas Turbines   Next in Forum: Steel Roof and Solar Hot Water
Grade of SS Wire?
08/23/2010 10:42 AM
Stainless Steel wire at least 6 gauge. How can I tell grade of stainless wire?
Tom
Re: $grade of ss wire/ at least 6gauge?
08/23/2010 11:16 AM
You can't tell by looking. You can't use a magnet.
Chemical analysis is the only way I know of if you don't have documentation.
Good Answers: 150
Re: Grade of SS Wire?
08/23/2010 5:49 PM
Get the MTR (Material test report) for the specific heat you were supplied with.
Who is John Galt?
Good Answers: 18
08/24/2010 12:12 AM
For determining the chemistry of the undiluted weld-metal derived from a welding consumable, a multi layer weld pad with dimensions approximately 40mm (l)*40mm (b)*15mm (h) is built ( min. of 6 layers) on a plate in flat position using stringer bead technique.
To avoid over heating the pad could be quenched in water periodically and this helps to overcome evaporation losses of base elements. Drillings or chippings are taken out from the top portion of the pad and analyzed by testing in the lab. But it is bit laborious and time consuming.
Alternatively, the welded pad could be ground and buffed to provide a smooth surface on the top and the specimen is subjected to spectra (spark) analysis. This is more easier and the results will be available in two to five minutes time as a print out. This method is more accurate and fast.
Sridhar.
What we have done for ourselves alone dies with us: while what we have done for other and the society remains and is immortal.
Good Answers: 58
08/24/2010 7:25 AM
If it's magnetic, it's 400 series. If it's not magnetic, it's 300 series. To further sort, you likely need chemical analysis.
Register to Reply 4 comments
lyn (1); Rorschach (1); SRIDHAR (1); welderman (1)
