I wish to prototype a small component from
3mm (1/8") C101 99.9% half-hard pure copper sheet.
The component requires folding into a
box-like shape and the fold line would be typically 50mm (2") long x a similar face
width although the starting tab would only be circa 25mm wide x 50mm long (1" x
2".)
I had thought of manufacturing an anvil
with a pressure plate above it to which would be attached a hinged folding
plate.
To maximize the force I had thought that I
would make the folding plate typically 300mm long (12") with an actuator connected
to the far end.
Can anyone please help me with the various
forces required as follows?
i.
The top pressure required on
the anvil clamping plate to resist being opened by the bending force.
ii.
The pressure required by the
actuator at 300mm (12") from the pivot point.
I would be most grateful for any kind
advice.
Thank you.
Christopher
