Previous in Forum: Saab 9-5 Heating Problem.   Next in Forum: Expedition Head Gasket
11 comments
Water Nozzle Spray Volume Measurement Tool
08/25/2010 7:00 AM
I am looking for an accuate measuring instrument for measuring volume of water that is spraying out of a nozzle. The water sprays out of many nozzles as a vehicle travels through a water testing booth. Any ideas?
Good Answers: 266
Re: Water nozzle spray volume measurement tool
08/25/2010 7:15 AM
Depends on what you need the data for. If you just looking for volume of usage a flow meter will do. But if your testing the vehicle as for water leakage in a storm the use a rain gauge.
08/25/2010 7:55 AM
I am just looking to verify the amount of water spraying from a single nozzle in a specified amount of time.
Good Answers: 60
08/25/2010 8:03 AM
connect flow meter to individual nozzels if all the nozzels are the same just connecting to one should give you the amount or divide the whole amount of water to all the nozzels by the amount of nozzels
ie 100 gpm divided by say 12 nozzels gives you 8.33 gpm
or attach hose to nozzel put hose in 5 litre container get stop watch turn water on time how long it takes to fill container and bingo you have volume from 1 nozzels then multiply by the amount of nozzels you have, job done.
08/26/2010 9:12 AM
I would put a plactic bag over the nozzle. Pick your time interval and then weigh or pour into a volume measuring cup. I do this all the time to determine the actual amount of powder spraying in application guns in a certain amount of time.
Good Answers: 60
08/25/2010 7:22 AM
a flow meter connected to the main water feed for the nozzels will tell you how much water is going out of the nozzels
08/26/2010 9:25 AM
Do you have any recommendations for brand or type? The lower the cost the better.
Good Answers: 60
08/25/2010 8:05 AM
  1. Flow measurement - Wikipedia, the free encyclopedia
  2. Optics InfoBase - Novel single point access fluid flow measurement ...
  3. OMEGA ENGINEERING - Flow Control
  4. ISO - ISO Standards - TC 30 - Measurement of fluid flow in closed ...
  5. IEEE Xplore - Ultrasonic pulse-phase method applied in fluid flow ...
CR4 Admin: Modified Post
Copyright Violation: Reduced copied text according to copyright law. Please see Section 13 of the CR4 FAQ about posting copyrighted material.
CR4 Admin 7/5/2018: removed broken and extraneous links
Good Answers: 60
08/25/2010 8:06 AM
Good Answers: 60
08/25/2010 8:08 AM
Good Answers: 60
08/25/2010 8:09 AM
the last one
CR4 Admin 7/5/2018: Removed broken and extraneous links
Re: Water Nozzle Spray Volume Measurement Tool
08/26/2010 3:51 AM
Why o Why can you not just measure the water before the nozzel turns it into a spray. This is simple and accurate as long as the nozzel are converting all the water into a spray i. e. they are not dripping with leaks.
Register to Reply 11 comments
Enamelman (1); Luminol (2); m()lly Mae (1); ozzb (1); peterg7lyq (6)
