Previous in Forum: NPT Temperature Rating   Next in Forum: Material Handling Arrangement for HT Motors
Flow vs Pressure
08/26/2010 12:57 AM
if air is forced to flow through a pipe, how will you relate the flow rate and pressure. does increase in flow rate always result in increase in pressure ?
Good Answers: 101
Re: flow vs pressure
08/26/2010 1:12 AM
08/26/2010 2:28 AM
See (or search) also: Darcy-Weisbach formula. Or fancier yet, Colebrook formula.
Re: Flow vs Pressure
08/26/2010 10:31 AM
The pressure required to generate a given flow through a pipe is a function of the physical parameters of the pipe and the fluid (in your case air). The flow rate of the air is related to the square root of the pressure differential between the ends of the pipe.
J B
DVader1000 (1); JBTardis (1); Tornado (1)
You might be interested in: Gas Flow Meters, Flow Meters, Turbine Flow Meters
