Previous in Forum: Motor Connection   Next in Forum: Bee's And Us
Looking for Pre-Set Timed Vibrator
08/27/2010 2:20 PM
in 2008 someone was looking for a pendant or pin that would vibrate on a pre-set timer. Did anyone ever find one or something similiar? Thanks
Re: looking for pre-set timed vibrator
08/27/2010 2:32 PM
Timers are easy, vibrators are easy, pendants are ...well pendants.
It's not rocket science... which bit do want to start with?
Please to those daft Q-link things, which have a few unrelated unconnected passive components and are s'posed to do something. Give my my lucky pants anyday.
08/27/2010 3:02 PM
"Give my my lucky pants anyday"
Cats wear pants? Who knew!
Re: Looking for Pre-Set Timed Vibrator
08/27/2010 3:01 PM
If you consult The Google, you can find a number of vibrating watches, bracelets and timers that clip to your belt.
http://www.amazon.com/Invisible-Clock-II-Vibrating-Reminder/dp/B00070QHE6/ref=sr_1_fkmr1_3?ie=UTF8&qid=1282935009&sr=8-3-fkmr1
http://www.amazon.com/CASIO-Pathfinder-Vibrating-Alarm-Fishing/dp/B000TJUPFM/ref=sr_1_4?ie=UTF8&s=watches&qid=1282935207&sr=8-4
Also you can find a few pendant type watches that vibrate, although the ones I ran across seemed to be a little pricey. I didn't search all that much, though. There may be cheap ones out there. Here's an example:
http://www.airwatches.com/item_detail.php?item_id=4703
I did run across this one jewlery-like pendant. At approx. $60 it also seems a little pricey. But most annoyingly to set the alarm time you put the battery in it at the time you want it to go off on the following day. A pretty inconvenient method if you ask me - especially if you want to change the alarm time often.
http://www.epill.com/chronostone.html
As always, I'm not recommeneding or endorsing any of the above products or vendors.
08/27/2010 3:16 PM
I must admit, the thread title brought me in!
I figured "Hey, a birthday gift idea for a certain ex-Mrs. Doorman".
I discovered the thread title, while accurate, is not quite... what I thought.
Good Answers: 60
08/28/2010 12:28 PM
I wonder what you thought ?
08/30/2010 7:41 AM
Being functionally deaf, my thoughts were obvious.
If you fail to follow through, you will fail.
Anonymous Poster (2); Doorman (1); otha (1); peterg7lyq (1); user-deleted-1105 (1)
You might be interested in: Counter and Timer Boards, PIN Diodes, IC Pin Probes
