Previous in Forum: Generator Sizing Calculation for Motor Starting   Next in Forum: Dover Elevator - Hydraulic Pump Shuts Off
Selection of Neutral Size for Different Load Applications
08/27/2010 9:08 PM
Selection of Neutral Size for different Load Applications!
Earlier Neutral use to be half of the phase in busbars as well as Breakers
Now applications like IT/Data centers neutral rating is twice of Phases due to harmonice
Just want to know more details from the experts,
what else could be the factors affecting neutral selection!?
Please save the power for Next Generation- Do ur bit
Good Answers: 244
Re: Selection of Neutral Size for Different Load Applications
08/28/2010 8:48 AM
Good Answers: 170
08/28/2010 9:07 AM
Not to ignore the level of unbalance in the single phase load distribution and utilisation amongst the three phases.
Engineering Fields - Electrical Engineering - New Member India - Member - New Member Popular Science - Genetics - New Member Technical Fields - Technical Writing - New Member Safety - ESD - New Member Engineering Fields - Power Engineering - New Member
08/30/2010 1:10 AM
mostly as you said third harmonic is the major cause of heating of the neutral.......and then the unbalance single phase loading.
Correct Me If Iam Wrong, Suggestions/Recommendations needs to be verified before implementation
Good Answers: 18
08/30/2010 6:55 AM
Earlier half size neutrals were there because the installing electrician cut costs. Consider what would happen to the half size neutral if you had a fault on the "full size" conductor and the half size had to carry that fault current?
The neutral cable should be at least the size of the conductors. However, if you do have a system saturated with harmonic currents, you should calculate the neutral size (Some installers double the size of the neutral as a rule of thumb).
Always learning
Register to Reply 4 comments
electricalexpert65 (1); jvrj (1); msamad (1); sms149 (1)
