Previous in Forum: How to Get a Single Frame/Image From a *.wav File?   Next in Forum: Install Application - Access Denied
Page Opens When Program For Any Files is Not Installed
08/28/2010 3:12 AM
Regards.
Page opens when program for any files is not installed
Please confirm if the site is safe:
http://www.filecure.com/lp/download/
Can't Open a File?
Ever get a file in an email, double-click on it and … nothing happens!? What do you do next? Probably frantically try to open it with every possible program you can think of, or spend valuable time trying to figure out what it is by looking up its file extension (such as ZIP, RAR, EXE, PDF) online. Don't waste your energy anymore. There is a much easier way... FileCure will help you open any file extension you need!
FileCure Scans Start When:
  • You try to open an unsupported file type
  • A file extension is entered into the search box
  • FileCure is manually opened
  • You drag and drop a file onto the FileCure Desktop icon
Download Now
Re: Page opens when program for any files is not installed
08/28/2010 5:46 AM
I haven't found anything that suggests it will actually do any harm - it seems to just keep popping up and asking you to buy the full version. It seems to be a scam.
For removal, it has been suggested that you should search your PC for ParetoLogic and delete anything you find. Make sure you check the "Search hidden files and folders" box.
08/28/2010 8:09 AM
I think this one is safe. You should only download software from sites that you know are trustworthy, cnet.com is a good one. You should also be extemely wary of opening links that come in email, regardless of who they are from, I don't do it.
Re: Page Opens When Program For Any Files is Not Installed
08/28/2010 10:37 AM
Googled for 'filecure.com'
see results on:
http://bit.ly/beVsS1
gone to:
"ParetoLogic File Cure" is it a scam? <http://able2know.org/topic/142389-1>
Almost everybody declared it scam
Searched for *filecure*.* in with baregrep.exe in my C:\
and found see image below:
Search4Filecure.jpg [ Before 'Deletet Temporary filaes' & After 'Deletet Temporary filaes' ]
Everybody here also suggested to search & remove the components
Thanks for all the suggestions
Register to Reply 3 comments
Haajee (1); JohnDG (1); kramarat (1)
