Previous in Forum: Centrifugal Pump   Next in Forum: Testing of Tyton Joint at Site
Power Plant Performance Calculations
08/28/2010 1:45 PM
Dear Sir,
I need thermal (Coal fired) power plant performance calculation and evaluation fundamentals/procedures.
Thanks.
Re: Power Plant Performance Calculations
08/28/2010 2:21 PM
Try searching. If you need help, call me.[PDF]
Geothermal Power Generation A Primer on Low-Temperature, Small ...
New Zealand - Member - Member Australia - Member - Member
Good Answers: 43
08/28/2010 11:08 PM
As a start, suggest you have a look at the ASME Power Test Codes. They are usually the criteria for formal/contractual performance testing of new plant. It will also depend on what type of plant you are seeking to test.
http://www.asme.org/
  • PTC1 - 1999 - General Instructions
  • PTC2 - 1980 (R1985) - Code on Definitions and Values
  • PTC4- 1998 - Fired Steam Generators
  • PTC4.2 - 1969 (R1997) - Coal Pulverizes
  • PTC4.3 - 1968 (R1991) - Air Heaters
  • PTC4.4 - 1981 (R1992) - Gas Turbine Heat Recovery Steam Generators
  • PTC5 - 1949 - Reciprocating Steam Engines
  • PTC6 - 1996 - Steam Turbines
  • PTC6A - 2001 - Test Code for Steam Turbines - Appendix to PTC 6
  • PTC6-REPORT - Guidance for Evaluation of Measurement Uncertainty in Performance Tests of Steam Turbines
  • PTC6-S - Procedures for Routine Performance Test of Steam Turbines
  • PTC7.1 - 1962 (R1969) - Displacement Pumps
  • PTC8.2 - 1990 - Centrifugal Pumps
  • PTC9 - 1970 (R1997) - Displacement Compressors, Vacuum Pumps and Blowers
  • PTC10 - 1997- Test Code on Compressors and Exhausters
  • PTC11 - 1984 (R1995) - Fans
  • PTC12.1 - 2000 - Closed Feed water Heaters
  • PTC12.2 - 1998 - Steam Surface Condensers
  • PTC12.3 - 1997 - Deaerators
  • PTC12.4 - 1992 (R1997) - Moisture Separator Reheaters
  • PTC17 - 1973 (R1997) - Reciprocating Internal-Combustion Engines
  • PTC18 - 1992 - Hydraulic Prime Movers
  • PTC18.1 - 1978 (R1984) - Pumping Mode of Pump/Turbines
  • PTC19.1 - 1998 - Measurement Uncertainty
  • PTC19.2 - 1987(R1998) - Pressure Measurement
  • PTC19.3 - 1974 (R1998) - Temperature Measurement
  • PTC19.5 - 1972 - Application, Part II of Fluid Meters: Interim Supplement on Instruments and Apparatus
  • PTC19.5.1 - 1964 - Weighing Scales
  • PTC19.7 - 1980 (R1988) - Measurement of Shaft Power
  • PTC19.8 - 1970 (R1985) - Measurement of Indicated Power
  • PTC19.10 - 1981 - Flue and Exhaust Gas Analyses
  • PTC19.11 - 1997 - Steam and Water Sampling, Conditioning, and Analysis in the Power Cycle
  • PTC19.14 - 1958 - Linear Measurements
  • PTC19.22 - 1986 (R1998) - Digital Systems Techniques
  • PTC19.23 - 1980 (R1985) - Guidance Manual for Model Testing
  • PTC20.1 - 1977 (R1988) - Speed and Load-Governing Systems for Steam Turbine-Generator Units
  • PTC20.2 - 1965 (R1986) - Over speed Trip Systems for Steam Turbine-Generator Units
  • PTC20.3 - 1970 (R1986) - Pressure Control Systems Used on Steam Turbine Generator Units
  • PTC21 - 1991 - Particulate Matter Collection Equipment
  • PTC22 - 1997 - Performance Test Code on Gas Turbines
  • PTC23 - 1986 (R1997) - Atmospheric Water Cooling Equipment
  • PTC24 - 1976 (R1982) - Ejectors
  • PTC25 - 1994 - Pressure Relief Devices
  • PTC26 - 1962 - Speed Governing Systems for Internal Combustion Engine Generator Units
  • PTC28 - 1965 (R1985) - Determining the Properties of Fine Particulate Matter
  • PTC29 - 1965 (R1985) - Speed-Governing Systems for Hydraulic Turbine-Generator Units
  • PTC30 - 1991 (R1998) - Air Cooled Heat Exchangers
  • PTC31 - 1972 (R1991) - Ion Exchange Equipment
  • PTC32.1 - 1969 (R1992) - Nuclear Steam Supply Systems
  • PTC33 - 1978 (R1991) - Large Incinerators
  • PTC33 - 1979 - Large Incinerators Codes and Appendix Package
  • PTC33A - 1980 - Abbreviated Incinerator Efficiency Test
  • PTC36 - 1998 - Measurement of Industrial Sound
  • PTC38 - 1980 (R1985) - Determining the Concentration of Particulate Matter in a Gas Stream
  • PTC39.1 - 1980 (R1991) - Condensate Removal Devices for Steam Systems
  • PTC40 - 1991 - Flue Gas Desulfurization Units
  • PTC42 - 1988 (R1998) - Wind Turbines
  • PTC46 - 1997 - Overall Plant Performance
  • PTCPM - 1993 - Performance Monitoring Guidlines for Steam Power Plants
10/21/2010 7:52 AM
Dear Mr. for coal fired boiler performance calculation, consider boiler design parameter and present performance parameter as below.
steam-TPH (both design and present running)
feed water tepm-Cel (both design and present running)
steam pressure-kg/cm2 (both design and present running)
Calorific value of coal (fuel)GCV- kcal/kg (both design and present running)
Steam to fuel ratio (s/f)-(both design and present sunning)
then apply formula for effiecieny,
boiler eff.= [(s/f)*(enthalpy of steam-enthalpy of water)] / GCV (Arb) = 75-85%
Also can calculate cost of fuel , cost of steam generated, cost of savings. the following cost ill explain you by mail.
my mail id: thyeeb123tco@gmail.com
Regards,
Mohamed Thyeeb-TCO
Anonymous Poster (1); AussieBob (1); lyn (1)
