Previous in Forum: Power Plant Performance Calculations   Next in Forum: How Much Weight Does a Chain Support?
Testing of Tyton Joint at Site
08/28/2010 11:57 PM
hi.. in DI pipes, is there any way of knowing if the tyton joint has slipped perfectly in the pipe or not...?
Good Answers: 141
Re: testing of tyton joint at site
08/29/2010 2:56 AM
Check this link. There is a file according Tyton joints and how to apply. If you respect temperature with assembly and the procedure of installation, it should be tight. However accidents can happen.
http://www.uspipe.com/Files/20071218851390.TYTON.pdf
Plenty of room here
