Previous in Forum: EPA to talk Clean Air Transport Rule at A&WMA Webinar   Next in Forum: Aluminium Composite Panel
Dual-Direction or Dual Action Hydraulic Damper/Cylinder/Piston
08/29/2010 5:30 PM
I am seeking a manufacturer of dual-direction or dual action hydraulic damper/cylinder/piston that allows resistance in each direction that is suitable for very lightweight fitness equipment. The working stroke length of the cylinder needs to be 500mm – 600mm with the ability to adjust resistance levels for the compression stroke and the traction stroke with a pressure/tension adjustment range of 10n – 120n (quite low). Additionally, since the working pressure is low, the cylinder itself need not be made of tough or robust steel, but could be made in an alloy or very light mild steel or even made in tough ABS plastic.
Can anyone help me to locate such a cylinder and/or manufacturer.
Thanks in advance of your kind attention and cooperation in my enquiry and I look forward to your reply.
Re: dual-direction or dual action hydraulic damper/cylinder/piston
08/29/2010 7:46 PM
Type this title into: Search GlobalSpec
Good Answers: 60
Re: Dual-Direction or Dual Action Hydraulic Damper/Cylinder/Piston
08/30/2010 12:23 PM
08/31/2010 2:35 AM
Thanks folks for your assistance. I'll take a look into these!
Register to Reply 3 comments
CornyC (1); lyn (1); peterg7lyq (1)
