Previous in Forum: Suggestions Needed for Copper Wire Coating   Next in Forum: TOW in Shopfloors
Tool & Die Vacuum Question
03/06/2007 8:56 AM
I'm trying to build a vacuum fixture for a sheet metal job. How much vacuum is needed to hold down a sheet 12.0x16.0x.032? Any help is welcome.
Re: Tool & Die Vacuum Question
03/06/2007 10:57 PM
"I'm trying to build a vacuum fixture for a sheet metal job. How much vacuum is needed to hold down a sheet 12.0x16.0x.032?"
You will need a welded steel box of 1/2" thick stock with the top surface-ground.
An area slightly smaller than the 12 x 16 work piece is drilled with a rectangular pattern of 1/8" holes on 1/8" c. to c. over the entire area into to vacuum chamber below. Use a Roots Blower as a vacuum pump. You are looking for a low gauge pressure, not a laboratory "high" vacuum.
The shop I was associated with part time had tried to use a large noisy vacuum cleaner and complained about the noise. The Roots Blower pulled a better vacuum and had the benefit of being much quieter.
04/21/2007 3:45 AM
Hold it down to do what? Is it steel, aluminum, SST? If you are machining aluminum an aluminum fixture with an "O" ring groove around the perimiter and a rectangular grid pattern will work just fine. The aluminum plate should be at least 3/4in thick. You can pipe tap the bottom of the fixture to attach your vaccuum hose.
United States - Member - New Member Popular Science - Weaponology - New Member
04/23/2007 3:32 AM
Is it steel, sst, or aluminum? What are you going to do with it? Machine it? Most machine shope make vaccuum fixtures out of 3/4 to 1inch aluminum plate with an "O" ring groove around the perimiter and at the location of each hole. You cut a grid pattern for the vaccuum based on the shape of the part, drill and tap a hole in the bottom of the plate for a pipe fitting for your vaccuum hose and that is about it. An air pressure operated vaccuum pump is usually enough or a refridgeration pump is even better. If you are going to drill a lot of holes in the part vaccuum may not be the best answer, in which case there are other tooling setups that would work. I would have to see the part to advise.
Men are like steel, if they lose their temper they are worthless.
Anonymous Poster (1); garyceng (1); Stirling Stan (1)
