Previous in Forum: IS IT SAFE TO USE DIESEL ENGINE OPERATED PUMP SET FOR NAPTHA SERVICE   Next in Forum: Can a Terminal be Over-Crimped
Diesel Fuel Conversion to Electrical Power
08/30/2010 1:26 PM
How to convert diesel fuel into electrical power, i mean 1 liter of diesel is equivalent to _____electrical power?
Re: Diesel Fuel
08/30/2010 1:54 PM
It depends on the efficiency of the generator and the % load. Here's something to get you started:
http://www.dieselserviceandsupply.com/Diesel_Fuel_Consumption.aspx
Re: Diesel Fuel Conversion to Electrical Power
08/31/2010 12:33 AM
For thermal applications, following calculations indicate conversion factors:
GCV of diesel = 9450 kcal/ltr.
combustion efficiency of fuel = 0.7 - 0.9, depending on the type of burner used.
(1) For low oil pressure burners, it can be taken as 0.7
NCV of diesel = 9450 x 0.7 = 6615 kcal/ltr.
1 KWH = 860 kcal
1 ltr. of diesel= 6615/860 = 7.69 KW
Practically, electric heating can be achieved in closed atmosphere. But for other fuels, like diesel, gas and solid fuels, chimney is a must. Taking into consideration, 25% (apprx.) heat losses through chimney, efficiency will be 0.75.
Hence, 1 ltr. of diesel= (6615 x 0.75)/860 = 5.77 KW
(2) For high oil pressure burners, combustion efficiency can be taken as 0.9
NCV of diesel = 9450 x 0.9 = 8505 kcal/ltr.
1 ltr. of diesel= 8505/860 = 9.89 KW
Hence, 1 ltr. of diesel= (8505 x 0.9)/860 = 8.9 KW
Good Answers: 137
08/31/2010 5:26 AM
Calorific value of diesel is 44 MJ/kg. Density is about 0.85 kg/ltr. Typical efficiency of diesel engine 35%, of alternator 90% (depending on size, bigger units generally better). So electric from 1 ltr = 44*0.85*0.35*0.9 = 11.78 MJ = 3.27 kWh.
Cheers........Codey
Codemaster (1); Mikerho (1); mn mahadevan (1)
