Previous in Forum: 3 Stage Steam Jet Vacuum and a Liquid Ring Pump   Next in Forum: Short Hand, SH, SHH, SLL etc
What is the Operating Liquid in Liquid Ring Pump
09/01/2010 5:23 AM
what is common operating liquid beign used in liquid ring pump?
Re: what is the operating liquid in liquid ring pump
09/01/2010 6:01 AM
09/01/2010 8:59 PM
A liquid ring vacuum pump compresses gas using an auxiliary liquid (normally water) as a liquid compressant, as sealing liquid and cooling liquid.
Good Answers: 27
Re: What is the Operating Liquid in Liquid Ring Pump
09/02/2010 4:02 AM
Water is a common medium for these pumps or compressors, but any liquid compatible with your process can be used as long as it has adequate vapour pressure for the service.
Just a comment on common useage - there are "liquid ring vacuum pumps" or "liquid ring compressors". Both are, in fact, positive displacement compressors.
I have no special talent. I am only passionately curious. Albert E
09/03/2010 1:55 AM
i remember there is an application in utilising partial vapour pressure. is the liquid ring pump appplication or steam jet vacuum system?
09/04/2010 12:11 PM
The type of liquid utilized sets the maximum pressure or vacuum possible.
The more viscous the fluid the greater potential pressure or vacuum.
Kaisan (1); lyn (1); russ123 (1); westdeap12 (2)
You might be interested in: Metal Ring Seals, Liquid Level Switches
