Previous in Forum: What is the Operating Liquid in Liquid Ring Pump   Next in Forum: Porosity Problem with Wheel Assembly?
Short Hand, SH, SHH, SLL etc
09/01/2010 9:49 PM
What do these bracketed short hands stand for? They always appear in P&ID. What I know for steam SL is at about 1.5barg to 4barg); SHH = 40barg:
condensate( CL, CH, CHH)
Steam (S, SHH, SH, SL)
Chilled water (WB)
Hot water (WH)
Pathfinder Tags: P&ID PID
Re: Short Hand, SH, SHH, SLL etc
09/02/2010 12:44 AM
The standard cited by Mikerho pertains more to the instruments and controls than to the fluids contained in the piping. I doubt that there is any universal standard that could cover all types of fluid, so you may be dealing with a semi-standard for an industry, a specific company, or a contractor. If there is no legend on the piping drawing, check the whole drawing set to see if there is a master legend.
I share most of your guesses so far: S = steam, L = low pressure, H = high pressure, HH = even higher pressure. I don't get WB, though.
09/02/2010 1:51 AM
you are right, there is a universal standard for symbols and representations. for the sake's of specific company and contractor, they use a little different kind of representatives which, you and i have to guess. Even, the symbol masterlist does not show all. I am dealing with palm oil processing from RBD hydrogenated stearin/olein to produce monoglycerides.
thank !
09/02/2010 12:51 AM
thank sir!!
09/02/2010 1:37 AM
You're welcome. You are asking the right sorts of questions, and I will try to be helpful.
Register to Reply 4 comments
