Previous in Forum: Short Hand, SH, SHH, SLL etc   Next in Forum: Surface Roughness
Popular Science - Weaponology - New Member Hobbies - Automotive Performance - New Member
Porosity Problem with Wheel Assembly?
09/01/2010 11:19 PM
It is an over molding part , Material : bearing and Nylon 6.6 ,
If you have a problem with porosity in wheel assemblies , how to solve them ?
Change the material Nylon 6.6 into Nylon 6.6 + GF 30 ?
Or use some extreme pressure grease ?
Or increase the gates on mold ?
Thank you in advance .
Not doing more than the average is what keeps the average down.
Good Answers: 69
Re: Porosity Problem with Wheel Assembly?
09/02/2010 8:20 AM
Hi Niya:
My experience is very limited on injection molding, so all I can tell you (because I used to see it a lot), is that you need to make sure your nylon pellets are being thoroughly dried before molding. Otherwise you'll have a severe porosity problem.
Check the air filters, air flow diverters, turbines and desicant level/age on your dryer.
Yahlasit
09/03/2010 5:31 PM
I agree with you. Nylon is especially moisture sensitive/absorbent.
Register to Reply 2 comments
You might be interested in: Diamond Tools and Wheel Dressers, Contact Wheels
