Previous in Forum: Mech Seal Failure   Next in Forum: Seeking for DIN, ISO, HES and ASME Standard Handbook
11 comments
Oil Storage Tank
09/02/2010 9:22 AM
I want to fabricate an oil tank having volume 24000 litres,6m height,2.256m diameter..we are going to fabricate this tank by rolling plates...what thickness of plate is required for the above specifications?
Re: oil storage tank
09/02/2010 9:25 AM
What specification?
09/02/2010 9:47 AM
specifications are volume of oil=24000 litres,height of cylinder=6m,diameter of cylinder=2.256m....
09/02/2010 10:56 AM
Cuckoo Syndrome?
09/02/2010 11:05 AM
Doesn't matter. I don't do metric anyway.
Re: Oil Storage Tank
09/02/2010 1:04 PM
banu....
Let the third world questioning begin...!!!
I assume that this is the first tank that you have ever designed...Is that correct ?
And you have no idea about the contents or the specific gravity of the contents...
And since the tank is not being built to any recognized code or standard, and since we have no idea about the quality of the welding or the type of material used......
I suggest that you use 0.25 inch (6 mm) carbon steel plate.
09/02/2010 2:07 PM
I was going to suggest 50mm A36 steel (2" for those who do not do metric) That should be enough. But, maybe not.
As you point out, we have all been trying to tell haruxa we need more information to come up with anything of any value.
09/02/2010 2:18 PM
Does, "6m height,2.256m diameter" really = 24000 L?
09/02/2010 2:37 PM
V= Πr2H
2.256*.5 = 1.128m (r)
1.1282Π ≈ 3.997 m2
3.997m2*6m ≈ 23.98 m3 ≈ 24,000L
No?
[edit] missed a pi, and added same.
09/02/2010 2:49 PM
If you say so. I don't do metric. Gives me a headache.
09/02/2010 5:38 PM
This is just metric homework anyway. A contrived diameter, 2.256m? Assumptions are inside dims, excludes ends, steel, no internal reinforcements, fixed on pad, USA, not insulated...
Me too.
09/03/2010 3:15 AM
Hello
look at this page from Outokumpu, you'll find a software for Tank Wall thickness Calculation, it's a nice tool.
follow the link under "design", Storage tank shell thickness calculation
http://www.outokumpu.com/applications/documents/start.asp
hope this can help u
S
corrosion & rust protection
Register to Reply 11 comments
Anonymous Poster (1); Doorman (4); haruxa (1); lyn (4); strider6 (1)
