Previous in Forum: Cooling Tower   Next in Forum: Oil Storage Tank
11 comments
Mech Seal Failure
09/02/2010 8:28 AM
Dear
We have real problem in our company most of mech seal fail due to suction pressure high than puffer seal seeting what is th best system to prevent mech seal from high suction pressure
Awad Elkarem
Good Answers: 27
Re: Mech Seal Failure
09/02/2010 9:13 AM
Awad, Welcome. You need to give us some more information. You mention "puffer seal setting" which I guess to mean "Buffer fluid pressure".
If this assumption is correct then we can assume that you have double seals fitted with an API Plan 53. Again if this is correct then your buffer fluid pressure may never be below the maximum pressure that can be experienced in the seal chamber under any circumstances, either static or dynamic.
Please give details of the seal system with barrier fluid pressures (refill pressure and maximum) as well as suction and discharge pressure of the pump etc and we will try to help.
I have no special talent. I am only passionately curious. Albert E
09/02/2010 9:56 AM
Dear
All your your information correct we use:
Mech Seal Burgmann SHFV (Double,Bulance,face to face and rotating seat)
Pump Centerfugal 4th stage(weir pump)
Buffer fluid pressure 45 bar(Buffer fluid also from Burgmann Auto fill system with Haskel pump and accomulator)
Suction Pressure normal 15 to 10 bar
Discharge pressure 65 bar
In normal operation we not face any problem but this happen at sudden shut down (prime mover is Engine) and trips suction pressure increace above Buffer pressure setting.
Awad Elkarem
Good Answers: 48
09/02/2010 11:23 AM
Would it be easiest just to fit relief valves on the suction, set at say 30bar?
09/02/2010 2:04 PM
When the main pump shuts down, relieve the pressure on the seal buffer fluid to a pressure below the suction pressure. That way the seal won't turn itself inside-out:
  • Buffer fluid vent valve, with quick-release arrangement fitted?
  • Trip the buffer fluid pump?
  • Etc.
09/03/2010 7:50 AM
Dear
At trips actual suction pressure buildup more than 60 bar , and seal buffer fluid 45 bar this cause fail of mech seal
Awad Elkarem
09/03/2010 8:10 AM
It is obvious from the first post as well as from the common sense that the suction pressure is likely to go up when the pump trips/stops. I am surprised why no one thought about that.
Anyway for your case obviously the seal is not well designed since the buffer fluid must take care of the worst case scenario- and that is the pump NPSH available on no flow.
Why don't you contact the seal manufacturer with the available data and ask whether the buffer fluid pressure can be increased. It would have its own effect on the loss of the life of the seal due to the larger pressure gradient in normal operation. and obviously the pressure reversals are not something the mechanical seals or for that matter any seal like.
talk to the seal OEM, may be go for a bidirectional seal.
Good Answers: 27
09/03/2010 8:56 AM
  • Buffer fluid vent valve, with quick-release arrangement fitted? Buffer fluid must remain higher than the pressure in the seal chamber at all times. For dangerous products this is deemed to be the shutoff head of the pump plus a safety margin. (Assuming spared service).
  • Trip the buffer fluid pump? Would not help as OP says ther there is an accumulator
Good Answers: 27
09/03/2010 8:09 AM
Awad, How does the seal chamber pressure increase when the pump trips? One assumes that there is a non return valve downstream of the pump, so when the pump trips the seal chamber pressure should revert to suction pressure.
Also, even if the seal chamber pressure increases to above the barrier fluid pressure, the product side seal will not see a very high differential pressure as the barrier fluid pressure remains 45 bar. A very slight contamination of the barrier fluid with pumped product should the only consequence.
The seal should in any case have full reverse pressure capabilities in case your outboard seal fails and you lose your barrier pressure.
Which seal fails - the product side seal or the atmospheric side seal. Also as this is a between bearing pump, do both drive and non drive end seal fail or only one?
What damage are you seeing on the seals? Are the rotating seats positively (mechanicaly) held in place so that they are not dislodged by reverse pressure?
When the pump stops suddenly are you getting excessive axial movement of the shaft?
Good Answers: 196
09/02/2010 11:12 PM
All good answers, guys. You're right on top of this. Hopefully the OP can understasnd what you said.
Ed Weldon
09/03/2010 8:01 AM
Dear
There is relief valve in suction setting at 60 bar connect with close tank ,it is easy to change setting bellow buffer fluid pressure 45 bar but we will face problem when station trip (there are four units in station) if all relief valves open i think this crude which returned through relief valve Will effect in close tank
Awad Elkarem
Good Answers: 48
09/03/2010 8:44 AM
You could, as someone suggested, increase the buffer fluid pressure to, say, 70bar to allow for the suction pressure increase at shutdown. Obviously the problem with this is that, when the pump is actually running the differential pressure between buffer and seal chamber would be more than 50bar; probably not a good idea.
As someone else mentioned, you should expect an increase in suction pressure at shutdown, but from 10-15bar up to 60-65bar? That's quite an increase. I don't know what your system looks like.
If you have relief valves in place on the suction side, you may have no choice but to reduce the setting, since you could argue that they are not doing their job at the moment, and make any modifications to the receiver tanks, etc that may be necessary.
Register to Reply 11 comments
Anonymous Poster (1); Awad (3); Ed Weldon (1); Holzfeller (2); Kaisan (3); PWSlack (1)
