Previous in Forum: Mass spring damper system   Next in Forum: Spotface
What is the function of bleed valve?
03/07/2007 5:50 AM
The Engineer
Good Answers: 129
Re: What is the function of bleed valve?
03/07/2007 8:46 AM
I'm sure there are tons of applications. Here is one definition:
"Bleeder Valve - A small valve on a pipeline, pump, or tank from which samples are drawn or to vent air or oil; sample valve."
Bleed - To drain off liquid or gas, generally slowly, through a valve called a bleeder. To BLEED DOWN, or BLEED OFF, means to slowly release the pressure of a well or of pressurized equipment.
http://www.lloydminsterheavyoil.com/glossary.htm
Good Answers: 61
03/07/2007 8:54 AM
T "bleed" valve is a valve installed for the intensional purpose of releasing vapor or liquid from a trapped space or container.
If you work on a car's brakes, you need to "bleed" the air out of the brake fluid system so the brakes work properly.
If you work in a process plant and you shut-down a part of a system for maintenance, you need to "bleed" down the pressure and maybe a hot fluid so the work can be done.
"Bleed" valves are installed for operation, maintenance and for safety.
I hope this helps.
Do it once and do it right
03/08/2007 4:32 AM
Thank you!!!
Anonymous Poster (1); Bayes (1); PennPiper (1)
