Previous in Forum: API Thread   Next in Forum: What is the function of bleed valve?
Mass spring damper system
03/07/2007 1:38 AM
hi, all
i m an electrical engg. student. i have a mass spring damper system which is placed on a vibration bench. this vibration bench gives sinusoidal excitation to mass spring damper system. i want to see all this happening in a software, so can anyone tell me which software i have to use.
thanx
Re: Mass spring damper system
03/07/2007 11:01 AM
If you're a student, your best bet is probably LabView by National Instruments. Most engineering schools have it, and it's fairly easy to use.
Good Answers: 18
03/07/2007 4:18 PM
Here's a place which apparently has mass-spring-damper applets available somewhere
http://mathinsite.bmth.ac.uk/html/applets.html
03/07/2007 11:07 PM
you might want to look at "Working model 2D" for motion simulation.
It simulates kinetics and dynamics.
United States - Member - Go Tigers! Engineering Fields - Mechanical Engineering - Specialty - Mechanical Vibrations Fans of Old Computers - UNIVAC - Man I shoulda bought a Whirlwind!
03/09/2007 1:11 AM
Ahh Mechanical Vibrations, my cup of tea...
If you're trying to plot motion:
m*d2x/dt2+c*dt/dx+k*x=sinωt
where:
m=mass
c=damping
k=spring constant (stiffness)
ω=frequency of the forcing sinusoid
solve the Diff EQ for x(t) (using some initial conditions ie-x(t)=0, dx/dt=0) since you're an EE student should be cake (if not let me know and I'd be happy to derive the solution for you).
Plug x(t) into any mathematics software, such as matlab, mathcad, maple, etc... and you have the motion.
If this is a experiment, collect data (displacement probe, laser vibrometer, accelerometer) and import into a modeling software such as ME'Scope (or equivalent).
If it is only a model, build the mass-spring-damper in ALGOR, Working Model, or equivalent and apply the forcing function (sinωt) and simulate.
Hope this helps!
"Your theory is crazy, but it's not crazy enough to be true." - Niels Bohr
09/17/2007 11:22 AM
dear fattmaxx!
am not a mechanical engineer but civil (poor @ mathematics!), however I would like you to derive a solution for an equation that I intend to use for a perturbation analysis of river morphodynamic system. The eq seems to make morphodynamic system analogous to a mass-spring-damper system. Eq contains real and imaginary part as well. Here is the equation:
∂2h/∂x2+2*Im(k)* ∂h/∂x+(Re2(k)+Im2(k))h=0
Re(k) is real wavenumber (of river bedforms), and Im(k) is damping coefficient
Need solution for h(x). If you need any further info please lemme know.
Thanking you in anticipation!
anaso (1); Anonymous Poster (1); Bill (1); fattmaxx (1)
