Previous in Forum: Pipe Wall Thickness Calculation   Next in Forum: Canadian Contract Grinder for CaCO3 for C.A.S.E usage
Water Properties
09/02/2010 3:23 PM
Hi. I've read that water is an electrecity conductor,because of the salt and the soils. So my question is - if destilated water ( with no soil and salt in it) is electrefied, would this be enough to break it molecule in hydrogen and oxygen?
Good Answers: 61
Re: Water Properties
09/02/2010 5:54 PM
As long as the applied votage exceeds about 1.23v., the the passage of a current through water will cause electrolysis i.e. the water is decomposed into hydrogen at the cathode (negative electrode) and oxygen at the anode (positive electrode). This occurs with or without the presence of most dissolved salts. Dissolved salts will only be decomposed themselves by higher voltages, so as long as water is present, it will be preferentially discharged and the salts will merely act as conductors for the electrical current. A better result is obtained by adding an acid or alkali to the solution because the H+ (acid) and the OH- ions (alkali) have the highest conductances of all, thus lowering the resistance of the cell. In practice you don't see much gas evolution until the applied voltage exceeds about 1.5v due to a phenomenon called "hydrogen overvoltage."
Trying to electrolyse absolutely pure water is a pointless exercise. The concentration of H+ and OH- ions present is very, very small (10 to the minus 7, each). If you measure the conductivity of ultra pure water ("deionised"), you find it has a specific resistance of a massive 20 Megohms per cm. Think of it this way, the ions in solution carry the current to the electrodes, but it is the solvent (water) that gets decomposed.
Good Answers: 60
09/02/2010 10:49 PM
09/03/2010 3:34 AM
<...Pure distilled water is an insulator....>
Only, distilled water ain't so pure.
Ultrapure water production for the semiconductor industry might use typically 17 stages of processing starting from town mains water before being distributed to users. A resistivity of 18.2MΩcm at 20degC would be typical. It still conducts electricity, only very little of it.
Good Answers: 60
09/03/2010 7:32 AM
09/03/2010 3:30 AM
There is a good article on electrolysis in Wikipedia.
energyconversion (1); peterg7lyq (2); PWSlack (2)
