Previous in Forum: The Earth's Mantle to be Studied   Next in Forum: Predictive Maintenance of Injection Machines
Air Flow Switch
03/07/2007 4:51 PM
I am looking for a air flow switch that operates at -.5 in w.c. It is for a old Trane gas furnace which they do not make anymore. Any suggestions?
Re: Air flow switch
03/07/2007 8:24 PM
I may have what you need, I'm not sure.
The markings on the device indicate that the product is a pressure sensor, made by Dumont. It measures about 1" by 1" by 1/2".
It has two pneumatic inputs, one for pressure and one for vacuum.
The part number on the device is PSF100A.
If this is of any value to you, contact me via my blog: http://solarjohn.blogspot.com
Since I moderate comments, your message will not be made public. Include your address if you want me to send this to you.
John
Re: Air flow switch
03/07/2007 8:31 PM
Even if you don´t find the original part you can always use any generic airflow switch. Look up www.dwyerinstruments.com.
Re: Air flow switch
03/08/2007 1:58 AM
Try your local Trane-gas-furnace-air-flow-switch-store
44mEurope
Re: Air flow switch
03/08/2007 6:04 AM
I'm presuming that the switch is proving air flow. Any three wire air switch will do. I favour the Kromschroder brand myself but Dungs do an identical range and no doubt countless others do also.
If I've done my sums right, your 0.5" WG translates to about 1.25 milli bar (mb). Kromschroder do a 0.4 - 6mb switch. From memory it's a DG6U. I can't help with the other brands but it should be a straight forward sourcing exercise.
An engineer is a man who can do for five bob what any bloody fool can do for a quid (Neville Shute)
Re: Air Flow Switch
03/08/2007 10:57 AM
Try a Cleveland air flow switch, available from multiple venders including Grainger (www.grainger.com). The typical range adjustable from .05 to 12 inch. It is commonly used to prove airflow across a fan. The switch would set outside the furnace with tubing running to static pressure pickup fittings on the high pressure and low pressure side of the fan. The pickup fittings are also available, although they are easy enough to make yourself.
Re: Air Flow Switch
05/05/2007 1:43 PM
If you are in the industry, and you install a non-standard part of a furnace, you liability is very high if there are any subsequent problems--even if your change was not the direct cause of the problem.
Even though the furnace is still not available, the exact part or a factory approved part should be available. I recommend you stay with factory approved components.
Register to Reply 6 comments
44mEurope (1); Anonymous Poster (1); coffeebean (1); Gadget Guy (1); Howetwo (1); nutwood (1)
