Previous in Forum: Sliver Quality Loosen(Weak/Poor) in RSB Drawframe (on Speedframe Grill)   Next in Forum: How to Calculate the Plate Wt. & Size
9 comments
Liquid Chlorine and HCl
09/05/2010 4:08 AM
Hi, I dont have a chemistry background, but I work at a company which manufactures chemicals. We produce Caustic Soda, but there is a large number Liquid chlorine and HCL produced as a byproduct. What other chemicals can we produce from these two byproducts that have high demand and also uses up the chlorine.
Good Answers: 109
Re: Liquid Chlorine and HCl
09/05/2010 10:45 PM
Just don't mix them as you will liberate chlorine gas.
NaOCl + 2 HCl → Cl2 + H2O + NaCl
Very dangerous to be around.
09/06/2010 9:41 AM
He did not mention mixing with NaOCl anywhere!?
Chlorine is the Cl gas normally.(?).
Good Answers: 109
09/06/2010 11:37 AM
No but Cl2 is a gas.
09/06/2010 3:11 AM
I think you company uses sea water to get salt NaCl to produce caustic soda. Generally and in order to avoid pollution most of companies utilize the byproducts generated from caustic soda production (chlorine and HCl ) to make hydrochloric acid, chlorine and sodium hypochlorite the 3 product are very valuable. how your company get rid of byproducts.
09/06/2010 4:22 AM
From very vague memory, isn't it the case that Chlorine gas is blown through molten scrap Aluminum/Aluminium, to purify it-- i.e. used as a flux?
Stuart.
09/06/2010 6:44 AM
talk to the local water treatment plants they all use both by products in the disinfection of water.
Good Answers: 179
09/06/2010 11:14 AM
For starters, your company can sell the chlorine products to any number of plastic manufacturers, say to make PVC plastic pipes, sheets and sectionals.
Search the www for other uses, and do your homework accordingly.
Have a great day!
Good Answers: 42
09/06/2010 12:23 PM
Chlorine and caustic gives sodium hypochlorite, which can be sold as bleach liquor based on available chlorine content.
If you can separate chlorine gas you can sell in gas form also.
Hcl if you can make it into concentrate by dewatering, it is again a potential market product.
Cost of conversion may be involved, which you got to refer to the process literature. If the volume is major , yes, you have the scope.
Anyway what is being currently being done in your company? normally chemical people never waste resources.
Take reading books, chemistry is a worthy self learning subject, but be cautious at your experiments
Nature is so graceful and naked. Human possession is ridiculous.
09/06/2010 2:23 PM
sell it to the Army.
Register to Reply 9 comments
Anonymous Poster (2); CaptMoosie (1); kel giesbrecht (1); kevinm (2); LAA_Lucke (1); Mohamed Wahab (1); s.udhayamarthandan (1)
